Increased MPG by 2+ for .50cents
Old May 7, 2005 | 10:48 PM
tienlo's Avatar
tienlo
did u pay 50 cents for AIR?
Old May 7, 2005 | 11:02 PM
Z BOY's Avatar
Z BOY
you know about the button, right?
Old May 7, 2005 | 11:03 PM
boma's Avatar
boma
Originally Posted by charlie_rdstr_Z
Aerodynamics comes into play if you have the windows up.
it even says in the owner's manual that driving with the ac on (windows up) versus the windows down (ac off) saves gas.
Old May 8, 2005 | 12:00 AM
rolling's Avatar
rolling
Yes the 50 cent was for air heh
the Button? do tell...
Old May 8, 2005 | 12:05 AM
Z BOY's Avatar
Z BOY
remember when they started charging for air? well here in cali, at least, a law was passed that made them put a little button, usually on the side or back of the air machine, that would allow you to pump air without paying. i have found these buttons on prolly 50% of the machines thus far.
Old May 8, 2005 | 12:19 AM
rolling's Avatar
rolling
Zboy!! omg! never heard any thing like that i coul dsave enuf money to become a "premium" member hehe THANX!!! yet another way these forums pay off!
thanx!! Z!
Old May 8, 2005 | 12:33 AM
Z BOY's Avatar
Z BOY
lol. anytime, bro.
Old May 8, 2005 | 01:12 AM
jreiter's Avatar
jreiter
Yes, but running the A/C unit isn't what saves the gas. It's rolling the windows up that does it. I'd be *very* surprised if running the A/C (all other things being equal) actually increased gas mileage. That's just completely counterintuitive.
Old May 8, 2005 | 04:28 AM
Armitage's Avatar
Armitage
^Yeah, running the AC has never saved gas before. I don't know why it would start now.
Old May 8, 2005 | 05:02 AM
bstansbu's Avatar
bstansbu
You guys that dont believe the AC method of saving gas, do an experiment for your selves. You will be surprised. All the test that I have conducted had nothing to do with windows up or down because they were always up to begin with during testing. Find a nice long stretch of road with near flat surface , no hills. Turn you mpg gauge on. Drive with air off for 30min or so at 60-65 mph with cruise on. Do the exact same stretch or similar with same variables and switch AC on. Watch your mpg climb +2. Works every time.
Old May 8, 2005 | 08:03 AM
1991TT's Avatar
1991TT
Originally Posted by DavesZ#3
That maximum pressure stamped into a tire is the max for a given rated load. Since those tires are not made specifically for the Z, that does not mean that you can put that much air in them safely. Nissan has already gone thru the trouble of calculating the correct air pressure based on the tire rating and the weight of the car, then factoring in performance, handling, ride quality, tire wear and safety.
Exactly. And they even went to the added trouble of placing a big sticker in the cabin with this information.
Old May 8, 2005 | 08:39 AM
rolling's Avatar
rolling
Ididnt get a big sticker in the cabin mine was used..
But if i get one put in there wil it give me and extra 5HP??
Old May 8, 2005 | 09:17 AM
Z04's Avatar
Z04
hmm well on my tires it says 44psi max, but with highter pressure is less rolling resistance i wouldnt go any higher tho.. there pretty hard riding
as far as the a/c goes ill give it a try but yea it dont make sence since the a/c compressor is a Drag on the engine!!
(why dont they make those electric too as well at the P/S pump heh)
thanx: for tip?
NEVER, and i repeat, never put what the max tire pressure says on a tire. this does not allow for expansion when hot and can cause a major malfunction of the tire. not a good thing if cruising at 70mph. even if you change the tire sizes, still only fill it to what the pressure says on the doorframe.
http://www.tiresafety.com/service/serv_nav1b.htm
Old May 8, 2005 | 10:50 AM
arejohn's Avatar
arejohn
80deg day in central NC and tire pressue goes from 35 cold up to 40 on my stock 05.
Gas consumption: AC and windows closed beats no AC and windows open.
Old May 8, 2005 | 10:57 AM
rolling's Avatar
rolling
Consumption: BUT does it beat No A/C windows up ANd vents set to fresh?
Old May 8, 2005 | 12:53 PM
arejohn's Avatar
arejohn
If you figure it out, patent it. It could make you rich.
Old May 8, 2005 | 03:34 PM
Reggi914's Avatar
Reggi914
55psi is plain crazy. Drop it to 35-40 asap
Old May 8, 2005 | 04:01 PM
  #38
the7ferret's Avatar
the7ferret
A/c works most efficently at highway speeds. Thats why you see the MPG go up.
A/C at city stop and go speeds is horrendus and will kill your MPG.
Old May 8, 2005 | 04:47 PM
  #39
DavesZ#3's Avatar
DavesZ#3
Unless Nissan has found a way around the Second Law of Thermodynamics, then the A/C will never increase your gas mileage. The AC takes energy to run. It takes it from the engine. To keep the same speed after turning on the AC, the engine will have to work harder and burn more fuel. More fuel means less gas mileage (at the same speed).
I find the window-up-less-air-resistance theory more believable than the A/C having anything to do with it.
Old May 8, 2005 | 05:00 PM
  #40
rolling's Avatar
rolling
yes guys i think i got the hint awhile back thanx again
