Increased MPG by 2+ for .50cents
Old May 10, 2005 | 07:28 PM
  #41
jreiter's Avatar
jreiter
Originally Posted by bstansbu
You guys that dont believe the AC method of saving gas, do an experiment for your selves.
I have, many times over. I drive to the Bay Area or Sacramento a couple of times per month to visit my girlfriend, friends and family. (It's about 200-280 miles each way, depending on where I exactly I go.) If I run the A/C I always get worse gas mileage. It's usually about 1 mpg worse with the A/C, but sometimes less. Obviously not a huge hit, but worse nonetheless.
Old May 10, 2005 | 07:55 PM
  #42
BIGDAWG75's Avatar
BIGDAWG75
You want a see a difference, try running nitrogen. I have it in my tires and have them set at 34 psi. Smooth ride and the tire wear is guaranteed to be minimal. The nitrogen doesn't allow for the pressure changes you will experience with air, especially due to temp changes. I suggest you check it out. I will post from time to time to report on the tire wear(if any).
Old May 10, 2005 | 08:08 PM
  #43
phile's Avatar
phile
yeah, but if you're into adjusting your tire pressure at the track, it might not work out...unless you bring a tank with you.. :P
Old May 10, 2005 | 08:12 PM
  #44
arejohn's Avatar
arejohn
My gas milage always goe up after I change the intake or exhause by 2+ mpg. I don't shift until I hear something that sounds like power.
hulkout
Apr 28, 2017 09:00 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
bcoffee20
Nov 19, 2015 06:39 PM
codek
Sep 28, 2015 03:03 AM
CrowzRSA
Sep 21, 2015 04:00 PM
