Heat Gun vs Blow Dryer?
Old May 24, 2005 | 11:50 AM
HotImportGirl's Avatar
HotImportGirl
Default Heat Gun vs Blow Dryer?
I just got my new emblems. Which is safer to use to get it off? Can I do any damage with the heat gun?
Old May 24, 2005 | 11:59 AM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Originally Posted by mc350z
i always used the blow dryer. and ive taken emblems off my z multiple times
go with the hair dryer it will do the trick. a heat gun could get too hot for your purposes
+1
Heat gun is quicker but if you don't know how to use it correctly, you'll have some well done emblems .
Old May 24, 2005 | 12:01 PM
BigMike's Avatar
BigMike
Just keep rubbing them, that will get them off. Oops, sorry, you meant your emblems. Heat gun could damage the paint. You just want to heat the adhesive so the hair dryer should do fine. Ever touch the car body after you've heated it with a hair dryer? Gets pretty damn hot.
What new emblems did you get?
Old May 24, 2005 | 12:02 PM
Bertg's Avatar
Bertg
Hair Dryer + dental floss should do the trick.
Old May 24, 2005 | 12:07 PM
HotImportGirl
I got the fairladyZ to replace 350z
Old May 24, 2005 | 12:28 PM
bstansbu's Avatar
bstansbu
Nice!! I have a really good friend that just happens to be Gay, he has a Z and got that same emblem, except he removed the Y from the end and put it after Fair. I think it fits him really good. Fairy Lad.hahahah Ok its late where I am, sorry for the stupid humor. Proceed. BEN
Old May 24, 2005 | 12:31 PM
HotImportGirl
Old May 24, 2005 | 01:18 PM
Low J.'s Avatar
Low J.
I've tried to remove decals with a blow dryer before and it just never got hot enough.....heat gun is the only way to go you just have to be careful.
Old May 24, 2005 | 01:46 PM
SOCAL350's Avatar
SOCAL350
Hair Dryer + thread......worked for me
Old May 24, 2005 | 02:37 PM
KenWH's Avatar
KenWH
Use 10lbs test fishing line to remove the hard emblem. Start at a corner of the emblem and work it back and forth to "cut" the hard plastic away from the spongey adhesive. Just remember your not trying to get all the adhesive off in this step.
Once the hard emblem is removed, use a product called Wipe Away to dissolve/remove the adhesive residue. Wipe Away is available at most autoparts stores like Autozone and is pretty strong stuff. Wear rubber gloves cause this stuff can burn your skin if it's not washed off pretty quickly.
Be sure to clean the area on the car after using Wipe Away. Also use some rubbing alcohol on the area before applying the new emblem. After it's all said and done, it would be a good idea to wax the area also since between the wipe away and the alcohol, any wax in the area would have been removed.
Old May 24, 2005 | 03:23 PM
longbowe's Avatar
longbowe
Old May 24, 2005 | 04:08 PM
GZire's Avatar
GZire
I'd say try the fishing line or (waxed) dental floss first. You may not even need to use a heat gun/dryer.
When I pulled my emblems I went with (waxed) dental floss only and this for the adhesive residue:
Old May 24, 2005 | 06:29 PM
KenWH's Avatar
KenWH
I agree, one shouldn't need a heat gun to remove the emblems. You run a higher risk damaging something with using the heat gun IMO.
I've seen what heat guns can do and putting one close to my Z's paint is something I really don't care to do. Using fising-line/thread/floss along with an adhesive remover is safe and I've found it's a fairly quick process to do.
Wipe Away is basically an industrial version of the citrus based Goo Gone. Either work but Wipe Away is a little stronger and comes in a much larger bottle for not much more $$$.
apex locator
Jul 23, 2021 02:27 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
