"SLIP" light comes on when driving normal
Old Jun 19, 2005 | 08:37 PM
5150FAST's Avatar
5150FAST
Default "SLIP" light comes on when driving normal
could it be a sensor? anyone have this problem at all ever?
the tires have good ground contact etc...
Old Jun 19, 2005 | 08:47 PM
damoniusmonk's Avatar
damoniusmonk
I got a new tire on one side on the rear and I got the slip light a few times on a good surface. I figured that the new tire was slightly stickier and was spinning a hair less than the worn tire. I don't get the light at all anymore, just when the tire was brand new.
How does this help you, you ask? Methinks it may be one tire spinning just a hair more than the other even though you don't feel it or hear it. Hope this helps.
Old Jun 19, 2005 | 09:13 PM
5150FAST's Avatar
5150FAST
all 4 tires are new.. thanks a lot for the input though... i am gonna take it in for them to look at it... thanks!
Old Jun 19, 2005 | 10:48 PM
westpak's Avatar
westpak
SFZCC
Are they the stock sizes or did you play with new sizes?
Old Jun 20, 2005 | 04:53 AM
5150FAST's Avatar
5150FAST
stock for now... i just got the car 2 days ago.
Old Jun 20, 2005 | 05:36 AM
sq40's Avatar
sq40
Easiest way to turn the slip light off is to remove your foot from the floorboard!
Other than that, Yeah, its probably a sensor, I would definatly have it looked at.
Old Jun 20, 2005 | 05:42 AM
5150FAST's Avatar
5150FAST
haha.. no im saying that it does it when im going 70 on the freeway in a straight flat line... im sure its a sensor... gonna have it looked at this week.
Old Jun 20, 2005 | 03:14 PM
IM Z MAN's Avatar
IM Z MAN
Make sure they didn't put the front rims on the back and vice versa. Since they had all 4 off the car they might have mixed them up. I Have seen this many times before. Rotated tires and no slip light. The front wheels are machined different so they fit the front hubs. The rear wheels fit but it screws them up if you do it. The bolt on the front hubs is for this reason.
Old Jun 20, 2005 | 03:54 PM
Fletch69z's Avatar
Fletch69z
Whooo. Man, that's scary. That's why I'm not taking my car to Walmart ever, .
Old Jun 20, 2005 | 04:11 PM
sq40's Avatar
sq40
Wow.. I didn't realize this..
That slip sensor will cut your throttle too.. Could be dangerous..
Old Jun 20, 2005 | 07:56 PM
Kolia's Avatar
Kolia
Your new tire was probably the one slipping. Tires get grippier with wear. And the first 200 miles or so are supah slippery because of the de-molding agent used when manufacturing the tire.
A missmatched front to rear tire is probably the problem here. A failled sensor should throw an error code, turning both VDC OFF a SLIP lights on for exemple.
Old Jun 20, 2005 | 10:40 PM
5150FAST's Avatar
5150FAST
thanks everyone... im still getting used to the 350... my other car is an ///M3. you can ask me anything about that car... lol..
Old Jun 22, 2005 | 12:10 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
what are your tire sizes?
Old Jun 22, 2005 | 09:10 AM
palmerwmd's Avatar
palmerwmd
I have the same problem both on my stock wheel;s/tires size and my new G35C rims same exact size as the touring wheel tire combo.
Taking it to dealere tomorrow
Old Jun 22, 2005 | 09:31 AM
Jason@Performance
Performance Nissan
turn car on...
roll back 10-15 feet...
roll forward 10-15 feet...
Old Jun 23, 2005 | 07:08 AM
Kolia's Avatar
Kolia
Originally Posted by mc350z
i had a similar porblem i was at the track and with VDC off the SLIP light came on and stayed on solid . it would not go off until i cut the car off then back on
weird.
Low brake fluid does that. Could be it.
Old Jun 23, 2005 | 08:28 AM
drew76924's Avatar
drew76924
my slip light would come on and not go off and that was the begining of new tranny #1
