sticking clutch pedal
I was drivine the Z one day and all of a sudden the clutch pedal stuch to the floor, I stepped on the pedal again than it poped up. never happen again anyone else have this happen to them?
Could also be your floor mats came apart from the little hook that keeps them in place and pushed downward causing your clutch to stick--happened to me and once I fixed the floor mat back into it's holder hasn't happened since...
Performance Nissan
Performance Nissan
what kind of clutch?
did you install headers or high flow cats / test pipes?
if so what kind of gaskets did you use between the header and cat on the drivers side?
if paper... or if you have an exhaust leak there... most likely the heat melted the protector over the clutch line and boiled your fluid... and you just got your car hot enough that it stuck...
ive seen it happen a few times...
Same thing happened to me when I was at the track. I went to Nissan dealer and the suggested I change the clutch fluid and replace with a high temp. fluid. I used Super blue brake fluid and have had no problems since.
