Dyno my 2003 Z with mods.
Old Jun 21, 2005 | 07:09 PM
donhuh's Avatar
donhuh
Default Dyno my 2003 Z with mods.
I dyno my Z using DYNOJET.. I did two runs and my best number is 246.42hp 242.38torque. SAE correct.
my A/F ratio was about 14 at 4500rpm and 13.5 at 5500rpm went down to 12.8 at 6000rpm. Is this safe?? am i running rich ??
My mods are Pop charger+test pipe+Greddy Evo2 exhaust. Im kind dissapoint at number.. I was expecting over 250hp.. cause stock Z dyno about 240hp. I will post dyno sheet later.
Old Jun 21, 2005 | 07:35 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
The ECU is programmed to get richer in the upper RPMs. Yours sounds normal. You can lean it up a bit by getting an ECU reflash.
Old Jun 21, 2005 | 08:17 PM
gdirty5's Avatar
gdirty5
and your in CANADA, the weather must be nice!
Old Jun 21, 2005 | 08:21 PM
Z BOY's Avatar
Z BOY
didn't you blow your engine?
Old Jun 21, 2005 | 08:26 PM
gdirty5's Avatar
gdirty5
Hey Z boy what front lip is that on your car?
Old Jun 21, 2005 | 08:28 PM
Z BOY's Avatar
Z BOY
cheapy nismo replica, but abs, which is what all front lips should be made of, imo.
Old Jun 22, 2005 | 04:16 AM
donhuh's Avatar
donhuh
no..
Old Jun 22, 2005 | 05:26 AM
egsmachine's Avatar
egsmachine
didn' happen to get a run before the mods did you?
Old Jun 22, 2005 | 06:17 AM
donhuh's Avatar
donhuh
NO im thinking to flash my ECU or get S-AFC II install and turned
Old Jun 22, 2005 | 06:55 AM
Z BOY's Avatar
Z BOY
Originally Posted by donhuh
no..
sorry bro, i had you confused with someone else.
Old Jun 22, 2005 | 12:17 PM
mavtais's Avatar
mavtais
You didn't baseline?!
So how do you know your car is any stronger at all?
Old Jun 22, 2005 | 01:58 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
If he gets it flashed, it will be stronger... he can use the current setup as a baseline now.
Old Jun 22, 2005 | 07:49 PM
donhuh's Avatar
donhuh
here is my Dyno graph.. A/F ratio seems safe to me.. I dont care about my Hp, I just want to makesure my Z isn't running rich or lean..
Old Jun 22, 2005 | 08:06 PM
Amnbex's Avatar
Amnbex
Dyno's are incredibly reliable measurements of performance.
/e-sarcasm off
Old Jun 23, 2005 | 07:01 AM
nicolaycastro's Avatar
nicolaycastro
I heard before there are different types of dynos, HP can vary alot between them.
Old Jun 23, 2005 | 08:19 AM
FairladyZ's Avatar
FairladyZ
Nice numbers, check out this guys.
https://my350z.com/forum/showthread....53#post1526753
Old Jun 24, 2005 | 04:49 AM
donhuh's Avatar
donhuh
some one please tell me my A/F ration seems safe ?? Do i really need reflash my ECU??
Old Jun 24, 2005 | 12:10 PM
DOHC's Avatar
DOHC
Your A:F ratios seem "okay" to me although at WOT closer to 13 would be nice. The ECU is set for emissions remember, not power. Forget about the bobble at 2500 rpm, that's an anomaly of the DYNOJET dyno at the start of about every run.
But I don't place a lot of faith in the typical DYNOJET A:F sensor. Stuck in the tailpipe it can give poor readings. Far better to put it in a bung welded into the system closer to the exhaust ports....like an oxygen sensor port for instance. But the typical dyno jockey only wants to get it done quickly and knows that most customers only want horsepower "dyno bragging rights" anyway.
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
kyin
Oct 15, 2015 05:54 AM
