installing jdm side markers?
Old Jun 28, 2005 | 04:00 PM
Timmy_boy188's Avatar
Timmy_boy188
Default installing jdm side markers?
I was wondering how you go about doing the swap the easiest way, thanks a lot
Tim
Old Jun 28, 2005 | 07:38 PM
mytherapy's Avatar
mytherapy
I changed mine out in around 20 mins. - fairly easily, without having to take off the bumper cover. I did have to lay in a few odd positions, but overall it wasn't bad and the new ones look SO much better. The secret is an offset phillips screwdriver and a little patience. To put my body in the correct position meant I couldn't really see what I was doing, but it's just four screws so just 'feel' them. As with anything else being done beneath the car, you will need some clearance - I used my Pep Boy ramps ($30) and took off the bottom engine cover. This may not be totally necessary, but I took it off anyway. Once you get the screws to 'break', they should just screw out the rest of the way by hand. The driver's side was a little easier, as the passenger side has the windshield fluid resevoir right next to it - it was a little more challenging, but again, taking the bumper cover off seemed like much more work. Hope this helps.
Old Jun 28, 2005 | 07:41 PM
MADDOG`'s Avatar
MADDOG`
Good tip, mytherapy! Not bad for your first post here. Keep up the good work.
Old Jun 28, 2005 | 08:08 PM
03Black350Z's Avatar
03Black350Z
Here is a link with pictures.
http://www.activetuning.com/pat/4/3/
Old Jun 28, 2005 | 11:50 PM
Timmy_boy188
thanks a lot that helps
May 30, 2017 03:28 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
