Problems With Z's Anyone?
Old Aug 8, 2005 | 01:25 PM
GoldenBoy75's Avatar
GoldenBoy75
Default Problems With Z's Anyone?
I just got a new Yellow Z... And my Navigation Door keeps Screwing Around... Any similiar situation out there... I also had Tire Pressure Light on !! And its Brand New
Old Aug 8, 2005 | 01:55 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
When I was at the service counter at the dealership I overheard a Z owner having problems with the Navi door as well
Old Aug 8, 2005 | 01:56 PM
Fletch69z's Avatar
Fletch69z
New cars always have some kinks that need worked out on them. I bought my last car (a spec V) new and I had to take it in a few times for random little stuff. Just enjoy your warranty and have them fix it quick.
Old Aug 8, 2005 | 02:02 PM
VO...'s Avatar
VO...
Administrator
I have a problem with the Z. Gas cost too much.
Old Aug 8, 2005 | 02:05 PM
sentry65's Avatar
sentry65
the burninator
when I had my 2004.5 model, I had issues with the dash door button now opening the door
my 2003 doesn't. It just works.
Old Aug 8, 2005 | 02:09 PM
DWS44's Avatar
DWS44
Only problem so far is with the drivers side window not sealing well near the back side (directly above the door handle) where it meets the convertible top...they've adjusted the window as much as possible, and it made it a little better, but they said the next option was to let the body shop work on the door itself. I'm not, however, eager to turn a brand new car over to a body shop! Think I'll just let it go as it is, as long as it doesnt start leaking!
Old Aug 8, 2005 | 02:11 PM
Mantis3024's Avatar
Mantis3024
just take it to the dealership. I had problems with my nav door opening and closing. I brought it back, they replaced it, and now theres no problems
Old Aug 8, 2005 | 07:56 PM
FLZ_Boy's Avatar
FLZ_Boy
Your tire pressure light will come on in a minute or so when your tire pressure is bellow 28PSI, if you look at your right instrument cluster it will tell you which tire is low. 35 PSI cold shold be the tire pressure for all 4 tires.
When I bought my Z, the tires had low pressure in them and I had to fill them up.
Old Aug 8, 2005 | 08:25 PM
AzianToby's Avatar
AzianToby
1 year later, my gas tank no longer takes a full tank. For some reason, it stops at the half way mark. I'm taking it to the dealership, hoping it's an easy fix. Other than that, the car has been a dream.
Old Aug 8, 2005 | 09:12 PM
Dream's Avatar
Dream
There's a TSB out for that. The forum has a gas thread active within the past few days that talks about it.
Old Aug 8, 2005 | 10:13 PM
AzianToby's Avatar
AzianToby
Sweet, Thanks for that bit of info
Old Aug 8, 2005 | 10:15 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
My nav door (I don't have nav) opens with the little button, but if you press it hard, it stays closed. It requires a light touch to open.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
