why is the track model so heavy?
Old Aug 13, 2005 | 12:03 AM
  #41
kcobean's Avatar
kcobean
Originally Posted by spcemn_spiff
If they weigh less and assuming that acceleration due to gravity is constant, then mass should be less. This is based on Newtons laws of motions (2nd) if they have not been refuted lately.
I think he mistakenly said 'mass' when in fact he meant to say 'volume', which for the purposes of this discussion would equal surface area.
And no, I think Newton is not going to be disproven any time soon.
Old Aug 13, 2005 | 12:20 AM
  #42
kcobean's Avatar
kcobean
The reason why most disk brakes at least on the front wheels have vents or vanes is for convection cooling, if mass were as important, some would increase mass and some would have vents. And its cheaper (manufacturability) to increase mass and not have vents. Z non-Brembos have vented rear brakes too, so the reason they went with vents instead of more mass is because of effective cooling.
Heat generated is dependant on the speed of the rotor, the more the speed, higher the speed of air flowing thru the vents because of the impeller based design of the vents, this results in better cooling at higher speeds. So mass seems to be a little disconnected from this effect. And if you think convective air flow is not a good way of cooling things, then radiators should not exist. I am not talking about infinite cooling potential either, I am just talking of keeping the temperature in the operating range, which is not infinite or impossible.
So again, we go to carbon fiber ceramic composite brakes is because of reduced mass and inspite of that better cooling, if you know Porsche and Ferrari use these rotors on their road cars, so the shift towards low mass indicates that mass is less important/effective in cooling the rotors. I have not done any calculations to analyze the heat transfer, but I know that increasing the mass to cool better is a completely wrong direction in my books.
About the 1300C quote, http://news.bbc.co.uk/sport1/hi/moto...de/3518465.stm
Its not the best source, but I cannot disregard it as being unreliable.
I think in order to quantify the effect of increasing mass as a way of reducing temperature, it's important to think about *where* you are trying to reduce that temperature. In this case, the "where" is on the surface of the disk where you're trying to control the temperature of the pad/rotor contact. For example, assume a convective cooling factor of 0. A heavier (i.e. thicker, but equal diameter) rotor will be able to absorb more heat away from the braking surface before the rotor is "saturated" at a given temperature. This is one of the reasons that a fire-safes' protective rating (which is measured in minutes of protection at a given temperature) goes up as it gets thicker. The safe itself can absorb more heat without actually being "bigger" (i.e. increasing its' surface area) before transferring the heat to its' contents.
Old Aug 13, 2005 | 06:46 AM
  #43
spacemn_spiff's Avatar
spacemn_spiff
I knew he meant volume.
I understand the effect of mass, but increasing the mass is not a good approach in my opinion and not used in cars from what I can see. Because chances are you will be running into heavy masses to absorb heat effectively.
There are two things that need to happen if mass approach is used and forced air convection is absent. One is increased mass will go on and absorb all the heat, now the temperature of the rotors and pads goes up. Second you need to cool the absorbed heat! You dont have convection, effects of radiation are minimal and for conduction there is not good enough thermal path.
So in essence theoretically there is no way of cooling the mass, all you are doing is absorbing the heat and not dumping it. That is not desired.
Old Aug 13, 2005 | 03:43 PM
  #44
dkmura's Avatar
dkmura
General & DIY Moderator
While the conversation on ceramic brakes is lively, it doesn't appear to contribute to this thread. There's little doubt that ceramic brakes offer some sizable advantages, the COST is out of this world as well. Porsche and Ferrari can offer the properly engineered brake application on cars that cost about the same as a nice piece of real estate. For those of us that WORK for a living and want the best braking on our Z's, steel and iron still offer the best bang for the buck.
Old Aug 15, 2005 | 05:49 AM
  #45
Kolia's Avatar
Kolia
Back from Tremblant...
Ah guys, stop being closed minded ! mass, airflow, conductivity and so on ALL contribute to brake performance. Stop trying to find one single source for everything, it's ridicule...
The mass argument (my argument anyways) applied to brake fade resistance. A heavier caliper will store more heat and keep brake fluid to a lower temps and resist boiling longer.
Mass of the rotor will play a role. Airflow cooling will certainly be a major factor in disc temperature and cooling. Surface area, vanne design and so on. But it will never cool the disc faster than heat is generated from braking (duh, obvious) and thus does not help much against temperature spikes and subsequent heat treatment while cooling. It will bring the temps down faster between turns.
Don`t compare F1 technology with amateur track applications unless you have a real knowledge of why things are this way in F1. Regulations do not care about what is the best/most efficient ways of going around a track... Did anybody ever wonder WHY they don`t use other disc brake material than carbon ? Why not ceramics? The answer is in the regulations (www.fia.com).
Old Aug 20, 2005 | 09:25 AM
  #46
track brembo's Avatar
track brembo
so what the TRACK still faster, stiffer, and look awsom with does big BREMBO gold rotors
Old Aug 20, 2005 | 05:34 PM
  #47
kcobean's Avatar
kcobean
Well, while I understand your bias (I have a track model too) you're wrong on both of the first two statements. The car being heavier will outweigh any aerodynamic advantage acheived by the tracks diffusers and other aero tidbits. Additionally, the suspension is identical to all the other trim-levels, so it is not in fact any stiffer. I agree with you though that the brembos look awesome, and they are the primary thing that makes the track model worth the money, even for a modder like me that has replaced everything else on the car that made the track model a track model.
Old Aug 21, 2005 | 06:39 AM
  #48
Kolia's Avatar
Kolia
Really ? New physics at work here ?
What hapenned to drag being a factor of speed to the power 2 ?
Anyway, the Z "feels" heavier than it is. If we take a look at many other sports car, the Z is pretty much average weight. A few pouds difference for different trim levels doesn't make a big enough difference to notice.
Old Aug 21, 2005 | 08:34 AM
  #49
kcobean's Avatar
kcobean
Yes, Drag increases the faster you go, but my point is that the better Cd you get with the Z isn't going to give it a performance advantage over a lighter car unless you're talking about constant high speeds, which very few of us actually do. Acceleration on either the 1/4 mile track, the street, and/or a road course is far more affected by unsprung weight than by aerodynamics.
Old Aug 21, 2005 | 08:45 AM
  #50
spacemn_spiff
+1 I concur. I dont know how much does the underbody diffuser weigh, should not for being plastic parts. I know performance nissan has them for $73 or so.
Old Aug 21, 2005 | 08:59 AM
  #51
Nano's Avatar
Nano
true
But when lapping with windows down (required by most schools and +)...
Forget any aerodynamic advantage/differences
on autobahn on 500miles trip it might make a difference
Old Aug 21, 2005 | 09:43 AM
  #52
Kolia's Avatar
Kolia
A right, I keep forgetting performance is mesured in 1/4 times.
If we consider only the Z. The weight difference between each trim level is minimal. I don't think it would make any noticeable difference. The diffuser and mini-lip are supposed to lower drag from .30 to .29. They also help on high speed stability. Which matters more for me. (Changing my exhaust pretty much screwed that. I'll have to reproduce the wedge from the OEM silencer to fix that.)
If we compare the Z with the competition well, it's not that heavy. The steering is pretty stiff and gives the illusion of being heavier. Its overall performance level is high enough that, on a full course race track, the driver will make the biggest difference.
Old Aug 21, 2005 | 10:11 AM
  #53
kcobean's Avatar
kcobean
Ha ha...Sarcasm..I love it. I'm not really a 1/4 mile guy either, and I know that this car is good for a LOT more autosport than that. All I'm saying is that I don't believe the aero kit on the track has as much benefit as lower weight in MOST circumstances.
I whole heartedly agree. The weight specs are so close that they matter about as much as the .01 difference in Cd.
right...define high-speed...120, 130? How many people actually get to drive on a track where those speeds are sustainable?
Agree 100%
Old Aug 21, 2005 | 10:17 AM
  #54
Kolia's Avatar
Kolia
Wheee, that was a lot of quote work !
Glad we're on the same side kcobean . I just like to throw different perspective in these conversations.
I'd define high speed as taking a turn at "only" 90 mph. Yeah you're right, not everybody is able or willing to do that.
Cheers !
Old Aug 21, 2005 | 07:47 PM
  #55
Nano's Avatar
Nano
I'd define high speed as taking a turn at "only" 90 mph. Yeah you're right, not everybody is able or willing to do that.Cheers !
Can you honestly tell the difference between taking a turn at 90mph with the stock muffler+diffuser... and tanabe muffler without diffuser?
If you can, you might have a place as a F1 driver
Old Aug 21, 2005 | 10:28 PM
  #56
qirex's Avatar
qirex
its all marketing crap...
the Z is fun, but it certainly isnt a great track car...
Old Aug 22, 2005 | 03:10 AM
  #57
Kolia's Avatar
Kolia
Been there already
The car does feel a bit different at speed. Wieght loss might be partly responsable also. I might have pictures some where, the Tanabe system leave a huge hole in the underbody !
Old Aug 22, 2005 | 06:07 AM
  #58
Nano's Avatar
Nano
stock, the Z is a good track car, nothing exceptional. In the hands of a capable driver it still flies. I've seen 350z blow past e46M3s, Carreras, Mcoupes, STIs, etc...
with a few modifications the Z has ton of potential and can be made into a track beast.
Old Aug 23, 2005 | 02:22 PM
  #59
BlackSpec02's Avatar
BlackSpec02
Alright, so you guys want to know where a bunch of that extra weight comes from on the track...
Well yes it has manual cloth seats... but it has AIRBAGS in both... which weigh more than you think. The track model also has curtain airbags as well... airbags and all the crap to make them work actually weighs a bit. So there's the x-factor that you guys weren't thinking of.... i win
Old Aug 23, 2005 | 02:28 PM
  #60
sentry65's Avatar
sentry65
the burninator
ummmm
track model in the US does not have airbags in the seats
just the front ones
