Valve Stems
Old Aug 23, 2005 | 09:53 AM
Escobar's Avatar
Escobar
Exclamation Valve Stems
Hey, I have a set of 19s on my Z, Ray's G-games and the right front valve stem is leaking air slowly where the stem connects to the rim I have called all over town and nobody has metal valve stems. where can I order any?? thanks
Old Aug 23, 2005 | 10:08 AM
sigsauer87's Avatar
sigsauer87
The local tire shop doesn't have them?
Old Aug 23, 2005 | 10:46 AM
Escobar's Avatar
Escobar
Nope, I keep calling around I guess...
Old Aug 23, 2005 | 11:45 AM
KenWH's Avatar
KenWH
Quick web search turned up these:http://www.speedpartz.com/real_valve_stems.htm
I've never ordered from them so I don't know if their safe or not.
www.summitracing.com has them as well. www.jegs.com probably does also.
Or check your local speed shops.
Good luck.
Old Aug 23, 2005 | 12:40 PM
VO...'s Avatar
VO...
Administrator
I would say to get them from the manufacturer.
Old Aug 23, 2005 | 12:50 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Its the same as these... basicly...
http://performancenissanparts.com/ca...oducts_id=1575
Depending on what is on your wheels (there are a few different valve stems available) it might be a different color but these will work...
Old Aug 23, 2005 | 06:53 PM
Escobar's Avatar
Escobar
Thanks, I found a set that should work for about $10
Rev_Night
Nov 7, 2020 06:00 PM
allmycarsdie
May 13, 2016 04:38 PM
azndoc
Wheels Tires
Oct 10, 2015 02:59 PM
tm9293
Wheels Tires
Sep 11, 2015 02:45 PM
