Just use 1st 3rd and 5th gear?
Old Aug 28, 2005 | 10:38 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Originally Posted by davidv
BTW sixth to second gear at 110 mph is not good. That's what I heard.
Yes, RPM is going to shoot up and bouce off the rev limiter like crazy again and again until speed decreases~! I've done 6th to 3rd accidently... That sucked...
Old Aug 28, 2005 | 04:10 PM
mdboy1213's Avatar
mdboy1213
maybe you guys should sell you Z so you dont have to row thru all 6 gearsand buy a hyundai... the car is a sports car and is meant to be driven like one.
Old Aug 29, 2005 | 12:15 AM
thrill350z's Avatar
thrill350z
well mdboy, you cant race everywhere and with gas so expensive it would be nice to improve the mpg
Old Aug 29, 2005 | 06:17 AM
DobbersNissanZ's Avatar
DobbersNissanZ
the car will be more efficient of you go through the gears, the gears will give you the best ratio for the acceleration you are trying to acheive. When going from 1st to 5th, don't skip 2 and 4! The gears are there for a reason! when you go to 3rd from 11st, you are consuming more energy than you would if you used 2nd to get to 3rd.
Old Aug 29, 2005 | 09:09 AM
yiaquemini's Avatar
yiaquemini
its totally fine as far as the tranny is concerned. just match the best gear with the rpm and speed. I redlined in 1st gear once and went to 6th because i hit the speedlimit in 1st, the transition during the shift was very smooth. It really dosnt matter which gear you go to as long as you goto a gear that fits a given rpm/speed situation.
Old Aug 29, 2005 | 11:30 AM
mavtais's Avatar
mavtais
Exclamation
Originally Posted by The Mike
Eh.. no. It's fine, just rpm match and you'll save money on gas and won't cause any undo wear and tear. I do it all the time since its my everyday driver. But I jump to sixth after 2nd sometimes... sixth will go just fine from about 30 mph.
That is way too early to shift into 6th. You will experience problems later on with your tranny if you shift too early. That's like saying "I start in 4th gear"
I agree that if you match rpm, you will be okay, with skipping gears (drive it like it's ford focus zx3), but matching rpm @ idle is not a good idea.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
kyin
Oct 15, 2015 05:54 AM
Conway_160
Drag
Sep 29, 2015 08:07 AM
