Fuel Pump Shut Off ???
Has anyone experienced or known to have the fuel pump shut off after a major accident? I was involved in an accident 4 months ago and the body has been fixed, but now the car wont turn on. The dealer has mentioned that there might not be a signal problem to the fuel pump.
Does anyone know how to reset it? How can I check to see if the fuel pump is working properly?
Thanks guys!...
Thanks guys!...
Originally Posted by Badmonkey_1
Check the fuel pump fuse. It is located next to the battery, under the plastic covers. I think it is the bottom right one.
NP. You have to remove the entire plastic around the battery, not just the plastic cover, to get to it. There is a fuse box under another black cover with tabs on each side. I hope that is all that it is. Good luck.
