Hawk HP+ don't fit Brembo front calipers?
Old Sep 4, 2005 | 06:46 PM
uwaeve's Avatar
uwaeve
Default Hawk HP+ don't fit Brembo front calipers?
Anyone else having this problem in the fronts? Back is OK. Seems like the backing plate long dimension is too big. I can get them in a little bit, but then they bind. And yes, the pistons are far enough into the caliper to accomodate the thickness of the new pad. The backing plate is definitely binding, even with some grease applied. Probably going to grind the backing plate down a bit, wondering if anyone else has had to.
uwaeve
Old Sep 4, 2005 | 07:06 PM
2003z's Avatar
2003z
you sir, are correct. When I had my Z, I had 2 sets of hps and one of hp+ and 22 of the 24 pads needed grinding down to fit.
Old Sep 4, 2005 | 07:08 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
some of the HPS pads even have this problem...
Usually the earilier produced pads...
Old Sep 4, 2005 | 07:20 PM
afr0puff's Avatar
afr0puff
I have used both HPS and the HP Plus with my brembos. Never had a problem.
Old Sep 5, 2005 | 05:56 AM
Primaltone's Avatar
Primaltone
Since we're on the subject, does anyone have any recommendations? My brembos squeaked the other day - could be dirt, could be time to replace the pads. I've heard the Hawk HPS are better than stock for reducing brake dust. TireRack.com has the HPS for about $173 all the way around. Are they worth the price?
Old Sep 5, 2005 | 07:56 AM
islandsnow's Avatar
islandsnow
yeah with HPS's, way less dust. It's a little cheaper here.
http://www.cvrmotorsports.com/view_p...=HB180F-HB181F
Old Sep 5, 2005 | 08:10 AM
Primaltone's Avatar
Primaltone
Thanks! I'll be able to buy a few gallons of gas with the change!
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
seagrasser
Oct 11, 2015 03:27 PM
hardkicks
Sep 20, 2015 12:28 PM
Alex Tappin
Sep 9, 2015 08:18 PM
