How well does the Z handle?
I currently have a 04 Mustang Cobra (suspension mostly stock minus some subframe connectors) but the thought of a 350Z has crossed my mind. My next purchase isn't about power, I'm more concerned with handling. Handling, being mostly on the street, maybe an autocross or roadrace event once or twice.
My car is nice, gobs and gobs of power (569 RWHP, Whipple charged) but man, it just doesn't handle, yeah yeah I know its a mustang...
I read up that the suspension is the exact same for all models? So this would mean the 350Z track edition doesn't necessarily outhandle the other models? Are the brembo brakes on the track edition worth it? I was looking actually at the performance level 350Z, invoice is right around 28ish,29ish...right along my price range.
How does this car handle compared to the Evo's, Sti's, E36's, E46's, S2000's, etc...?
thanks!
thanks!
Originally Posted by MeetJoeAsian
for the price...it's badass...
vs. say spending $17K on a used 95 E36 with 65,000 miles? I know i'm comparing new vs. used, not exactly 'apples vs apples' comparison.
Performance model is invoiced according to Edmunds for 28,XXX, so If I pick one of these up for $31K or $32K OTD, its definitely worth it? If I like to stop how a ZO6 stops, maybe I should be looking at the track edition?
Do Z's suffer from Wheelhop? What's there suspension consist of? Are the struts seperate from the springs? (non coilover setup in stock form)
The struts are separate from the springs in the rear. Some, if not most aftermarket coilovers for the Z retain this configuration.
As for your other concerns, t
he Z is one of the most stiffest chasis cars I've ever driven. Comes out of the factory with a little understeer but nothing a good set of tires and $300-400 set of aftermarket sways can't dial out.
thanks
Im researching on this board and found that the limited slip is available in enthusiast model, maybe the enthusiast is what i'm after? I'm not sure if I really need the VDC system, seem's a little overkill for me.
Get an enthusiast and upgrade everything yourself.
Here is a link to what a real 350z should be like. JK
http://rickdogg.onlineshowoff.com
i can say from owning an s2000, the s2k feels somewhat the same, but has a different feel on curves, but the Z has amazing grip and can take corners at high speeds as long as you are able to control it depending on the situation goes.... this car is a track monster compared to s2k, and m3. Not sure on those awd cars, dont care much for them.
Enthusiast sounds right for you. If your buying new, the Performance model has been eliminated.
I intended to buy the Enthusiast but I wanted Brickyard (color), no spoiler, & wanted it "right now" in 12/02. Only model I could find in that combo in the state was the Performance. Love it but I would have been happy with Enthusiast.
Here’s an interesting article comparing the price and performance of several sports cars including the 350Z.
http://www.roadandtrack.com/article....&page_number=1
lol..I laugh because that magazine is still reading material in my bathroom, and I just set it down not more than two minutes ago...
I was not aware that the perf. model was discontinued, that leaves me with either the enthusiast or the track model. If I were to purchase the enthusiast, how much am I looking dollar wise to upgrade to the brembo package found on the track model? I'm sure brembo makes even bigger packages than that, but roughly speaking anyone have an idea? Maybe I just need the track model If I want those brembos so bad. I'm a sucker for a car that brakes on a dime.
thanks everyone for the help, greatly appreciated!
I've read that article over and over, amazing how the Z outlapped all other others in regards to time...
Wheelhop is going to be an issue when dropping the hammer with anything that has both power and an independent rear suspension. That's why your Mustang has a live rear axle. It is the best for stoplight to stoplight and drag strip racing, which Ford figures most of their customers do most. The tradeoff for better handling through an IRS is not as good of traction and 1/4 mile times as a result. That's what you can't get most people with those types of cars to understand... they love to tell you how your car is a "dyno queen" because it makes lots of horsepower but it doesn't put out the 1/4 mile times of a Camaro or Mustang with the same amount of power. They convieniently forget the Corvette has the same problem though.
Really, as far as handling goes, the Z is one of the best in it's class. Stock for stock the S2000 has better handling and is a better track car, but it is totally impractical on the street because of the nature of the convertible top and the nature of the engine having to have the **** revved out of it to get that power. The all wheel drivers have superior traction on anything other than fresh pavement, but they also suffer from chronic understeer, lack of low-end torque/turbo lag, and drivetrain losses... plus more complicated and expensive to upgrade, repair, replace if that is an issue for you. I don't have much experience with BMWs, but I believe they have some weight issues just like the Skyline/G35 Coupe for the same reasons... lots of added and unnecessary luxury items(but they may make a better car for you if this is going to be your daily driver and that kind of thing is important to you).
There are pros and cons to the Z just like any other car, but it seems do the "jack of all trades, master of none" better than almost any car in the class and pricerange. At least for me it does. Your experience, like your tastes, may vary.
Made the same decision you are considering and haven't looked back. The Cobra I had was a few years older than yours and without f/i, but I found it lacking in the corners, so on went adj. shocks, springs, subframe connectors, fat wheels and tires, caster/camber plates, bump steer kit, etc. etc.
Even with all that my Z with the stock 17" tires would run circles around it on a track and with better ride quality, feedback and braking. Note: the stock brakes share the track models stopping distance, but not their fade resistance at the track. The Z's chassis stiffness is second to none...you will be shocked when compared to the Mustang.
Only now I'm having the exact opposite problem, now I've spent over $2000 on engine mods with little improvement. I suggest f/i if you crave power to match the Z's handling prowess.
I also enjoy the Z forums more, the owners are generally more knowledgeable about all cars-true enthusiasts vs. the Mustang crowd that tends to bleed blue. Z owners can be a tad superstitious though, as I don't think you'd be able to sell grounding kits to many Mustang owners. =)
Originally Posted by nicolaycastro
I have an Enthusiast moderl and it brakes great without the brembos. But if more brakeing powere is what you want you could probably get some grat stoptechs for around $3000, heck you could probably get the brembos for that in the classifieds section if thats what you want, I still would personaly go fot the big brake upgrade stoptechs.
get an enthusiast or performance if there is still one on the lot. and since they are trying to get rid of 2005s for 2006 you could get a good deal and then if you wanted add some $400 sway bars and some stoptech brakes and you will be fine. then later on down the line you can buy some TEIN flex coilovers for amazing handling.
How much should I be paying OTD for an 05 enthusiast? our sales tax is 8%. No way I can trade my car in, too much money in mods need to sell it to someone who can appreciate the car for what it has done to it, but yeah soon as It gets sold I will run over and check the 05 inventory on dealership lots, try and score maybe an enthusiast model (05) for around 31K OTD?
