The 350Z (and all internal combustion...
Old Sep 9, 2005 | 02:45 PM
Default The 350Z (and all internal combustion...
engines) create energy by burning fuel and oxygen. Air is approximately 80 percent nitrogen and 20 percent oxygen. Cold air is more dense than warm air: therefore, cold oxygen is more dense than warm oxygen.
The force created by and explosion of fuel and dense air (cold) with be greater than the force created by fuel and less dense air (warm).
Is this correct? Am I on the right track trying to explain why my car is faster when the temperature is 60 degrees rather than 80 degrees?
BTW lets hold a discussion about humidity for another day.Thanks for your help.
Old Sep 9, 2005 | 03:29 PM
Navygold's Avatar
Navygold
Davidy, you are correct...more the most part. It falls under the same principle as why cars tend to perform better at lower altitudes than higher altitudes.
Let me know when you want to have that humidity discussion...it throws off everything.
Old Sep 9, 2005 | 03:30 PM
Fletch69z's Avatar
Fletch69z
Yep, you got it.
Old Sep 9, 2005 | 04:13 PM
Speedracer's Avatar
Speedracer
In general you will have about a 1% gain in horsepower for every 10 degree Farenheit drop in air temp. The difference in power on a stock 350Z will therefore be about 6 hp between a 60 degree day and an 80 degree day given equal humidity. Humidity is a big factor, however, and in many parts of the country, goes hand in hand with heat. Water vapor lowers the partial pressure of the oxygen in the atmosphere as well. The difference in engine power output on a dry 20 degree winter day and a muggy 98 degree summer day can be over 40hp.
Old Sep 9, 2005 | 06:02 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Sounds like someone discovered PV=nRT !!!!!! LOL
(I know air is not even close to being an ideal gas - don't get me started)
Old Sep 9, 2005 | 09:21 PM
“(I know air is not even close to being an ideal gas - don't get me started)”
Why is NOS popular? NOS is Nitrous Oxide: one part nitrogen and one part oxygen. Why not just leave out the nitrogen, and run pressurized oxygen?
Old Sep 9, 2005 | 09:29 PM
Immortal's Avatar
Immortal
One of my friends really thought of doing that, running small shots of oxygen, never did apply it.
Old Sep 10, 2005 | 02:07 AM
the7ferret's Avatar
the7ferret
good question...
My best guess would be too corrosive..
Old Sep 10, 2005 | 05:05 AM
danvain's Avatar
danvain
Well, with N2O...aren't you upping the Oxygen intake to 33% vice the normal 20%?
Old Sep 10, 2005 | 05:06 AM
danvain's Avatar
danvain
Oh, and my plan is to do everything I can to my Z on the NA side and then spray it.
Old Sep 10, 2005 | 05:07 AM
rockinbboy's Avatar
rockinbboy
Probably cause of the KABOOM! effect.
Old Sep 10, 2005 | 05:53 AM
DaytonaBlue04's Avatar
DaytonaBlue04
Rather than nitrous, inject oxygen and acetylene.
Old Sep 10, 2005 | 07:19 AM
That's what I suspected. The pressurized oxygen-fuel burn creates too much heat. Maybe that's the problem.
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
codek
Sep 28, 2015 03:03 AM
