Do you guys drive around with no spare tire?
Old Sep 13, 2005 | 06:53 AM
  #41
nicolaycastro's Avatar
nicolaycastro
Originally Posted by mc350z
i think i noticed it from the combination of the spare being out and the empty tank of gas. i think one factor by itself might not be enough to notice the difference that i did
True, I think that if you are going to a track and you have a full tank of gas you might as well remove the spare, if you have less than half a tank I would leave the spare. In thw other hand if you are going to drag, then i would sugest taking the spare off, but who knows may be having that little wight more on the back makes the traction tires stick more.
For street driving I dont think is goin to make that much difference if anything at all. JMO
Old Sep 13, 2005 | 07:33 AM
  #42
Spooky's Avatar
Spooky
Originally Posted by redvert
Simple fix to not having a spare. carry around a plug kit you can get one for about five bucks with several plugs. get the one with the pistol grip you can get a better grip. i also carry a small air compressor to plug into the lighter.
+1
Old Sep 13, 2005 | 09:05 AM
  #43
corsair's Avatar
corsair
Yanked the spare and tools a long time ago. I wouldn't feel comfortable using it anyway.
Old Sep 13, 2005 | 09:14 AM
  #44
njsho's Avatar
njsho
I wonder if the fix-a-flat has any effect on the tpms sensors? I could see that stuff coating them and clogging something making them unusable in the future? Doesnt it also say on the can of fix a flat that its not supposed to be used on Z rated tires (not sure on that?)
Old Sep 13, 2005 | 09:34 AM
  #45
elms350Z's Avatar
elms350Z
So will the stock 18's fit in the trunk if you were to get a flat???
Old Sep 13, 2005 | 09:38 AM
  #46
spf4000's Avatar
spf4000
I've always had the same question about fix-a-flats. Not to mention all the goop in your tires that the tire installer has to wipe off when he removes your tires. I'd rather use a plug and a compressor, even though it's a bit more of a hassle.
Old Sep 13, 2005 | 09:56 AM
  #47
harrieyu's Avatar
harrieyu
yes 18s will fit in the place the spare was. but only temporarily
416blueZ
Jun 11, 2024 10:56 AM
etkms
Jun 19, 2022 06:30 PM
bcoffee20
Nov 19, 2015 06:39 PM
RiujinZero
Sep 25, 2015 01:19 PM
416blueZ
Sep 24, 2015 02:11 PM
