Question from a potential UK buyer!
Old Sep 20, 2005 | 11:05 AM
khaa1329's Avatar
khaa1329
Default Question from a potential UK buyer!
Hi guys!
I am thinking to buy a used 350z from my local dealer. Just a quick question to find out how I can be sure that I am buying a UK car not an import from europe or Japan. Any way of telling without taking the dealers word for it?Also I have heard that the car requires super unleaded fuel (we have two types of unleaded in the UK) is that true?
Thanx.
Old Sep 20, 2005 | 11:17 AM
bixby's Avatar
bixby
All Z's are manufactured in Japan so I'm not sure why it would matter. And yes, 91 octane is a minimum requirement.
Old Sep 20, 2005 | 12:07 PM
khaa1329's Avatar
khaa1329
Matters because of insurance issues over here, alot more expensive to insure an import.
Thanks for the post.
Old Sep 20, 2005 | 12:14 PM
elms350Z's Avatar
elms350Z
Hard to say... like bixby said they're all manufactured in Japan. There are noticable differences in the American Z vs Europeans but I'm not sure about UK Z's.
BTW I asked some Z guys in this forum a question before and they were pretty helpful. Good luck.
350zUK.com
Old Sep 20, 2005 | 01:56 PM
li350z's Avatar
li350z
Find the model identification number on the plate inside the drivers door jamb, tells if the car is a USA model or a CANADA model. It should read something like GLJALSYZ33-EUA.The U is for USA, N is for CANADA. Also the 4th digit is L for left hand drive, R for right hand drive.
If this does not answer your question, go to a Nissan dealer and ask to see a service manual.
Old Sep 20, 2005 | 02:35 PM
bixby's Avatar
bixby
Here ya go.
http://www.courtesyparts.com/specs/vin.html
Good idea li!
Old Sep 21, 2005 | 04:04 PM
350doc's Avatar
350doc
Japanese spec models have a square number plate at the rear (rather than rectangular); they are speed limited to around 110mph; the radio needs a frequency expander, there are no headlamp washer jets fitted (this is a EU requirement for Xenon hedlamps). Also look at the original DVLA document. If a UK Nissan dealer syas that the car is a UK model, then it should be. The European are identical spec to the UK ones (unless they are LHD).
Old Sep 21, 2005 | 04:07 PM
350doc's Avatar
350doc
In the UK, a 98 RON fuel is recommended (i.e Shell Optimax); though you could use other Super Unleaded such as BP/Esso. Regular unleaded is not recommended, as the ECU remaps for lower octane petrol, and you will get a performance drop. The ECUs are mapped for different octane ratings around the world; for instance, in Japan 100 RON is popular, so the Japanese ECUs are mapped slightly differently to EuroSpec.
The EU/UK manual states that regual unleaded may be used 'in an emergency' and that a minimum amount should be put in until 98RON petrol is available.
Shell Optimax is 98 RON, other Super Unleaded fuels in the UK are 97RON.
Old Nov 14, 2005 | 02:02 AM
paulsmansfield's Avatar
paulsmansfield
I occasionally use 'normal' fuel in mine, can't really notice any difference, I'm told by local dealer that no damage will be caused by using it.
