parking in gear
Old Sep 20, 2005 | 12:25 PM
thief's Avatar
thief
Default parking in gear
i was curious about how many people when they are parking their car do they leave it in 1st gear or neutral. if so, whats the point of leaving it in 1st gear?
Old Sep 20, 2005 | 12:30 PM
Bertg's Avatar
Bertg
Always leave it gear - 1st or Reverse. If for some reason the parking brake fails, your car won't roll away.
Old Sep 20, 2005 | 12:31 PM
MannishBoy's Avatar
MannishBoy
I agree, for bertg's reasons.
Old Sep 20, 2005 | 12:32 PM
Methane's Avatar
Methane
I always leave it in gear, even if im parked on level ground. Never trust the parking brake!
Old Sep 20, 2005 | 01:07 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
+1
This is why I always put mine in gear.
Old Sep 20, 2005 | 01:14 PM
CLETUS's Avatar
CLETUS
always in gear 1st if facing uphill and reverse if facing downhill. one day at work i just happened to look outside and see one of our tech's neon roll through our parking lot slightly down hill and into a brand new hemi ram that was a demo for one of the managers. did't do anything to the truck, but the neon needed a new fender, headlamp and hood, which was pricey bc it was a dohc. i just looked up and saw the whole thing.
it would also be much harder to roll if the parking brake wasn't on and someone yanked it with a flat bed........teh chances are slim, but i have seen stranger things.
Old Sep 20, 2005 | 01:41 PM
and to add...
Downhill: the front wheels are turned into the curb.
Uphill: the front wheels are turned away from the curb.
Temperature below freezing:emergency brake OFF.
Old Sep 20, 2005 | 01:48 PM
Clapton9286's Avatar
Clapton9286
What are the reasons for E brake off in frozen weather? Brake fluid freezing?
Old Sep 20, 2005 | 02:20 PM
No. The emergency brake (linkage) can freeze ON. If that happens, you can try to drive the car with the emergency brake ON, but it will stall regularly. Or you can wait until the front brakes thaw.
Old Sep 20, 2005 | 02:27 PM
harrieyu's Avatar
harrieyu
when parking always put the parking brake on first and then after the car rolls the inch or two that it always does, then apply the gear accordingly. dont want to put unnecessary stress on the gears.
Old Sep 20, 2005 | 02:34 PM
Fletch69z's Avatar
Fletch69z
Always in gear. Unless you like having to figure out where your car went when you come back, .
Old Sep 20, 2005 | 02:36 PM
TomeiZ33's Avatar
TomeiZ33
Vendor - Former Vendor
From personal experience I had my prevoious car roll off my drive due to not leaving the car in gear when parked. Especially when you have a car over 3000lbs the E brake will give a little as time goes by. I most definitely make it a habit to leave my Z in gear when parked. I've had my track for only a few months and the e-brake does not seem to hold the car when i'm parked on a steep driveway or hill. In gear will always insure that your car is safe.
Old Sep 20, 2005 | 02:39 PM
Fletch69z's Avatar
Fletch69z
+1, the ebrake in our cars sucks.
VO...'s Avatar
VO...
Administrator
I agree with this statment only when the pavement is not at too sharp of an incline/decline. A couple of weeks ago I went to the Houston Cruise to Galveston Island. We parked on this really steep slope. I shut the car of and place it in gear. I slowly let off of the brake pedal, so the car's weight could rest on the transmission instead of my e-brake. The car started rolling. I tried several gears, but no luck. Finally I had to engage the e-brake pretty hard and let the car's weight sit on that. He is a link to some pictures of the slope I'm talking about.
https://my350z.com/forum/texas/138169-houston-galveston-z-and-g-cruise-pictures-8-21-05-a.html
Old Sep 20, 2005 | 02:45 PM
bixby's Avatar
bixby
+1 And I'd like to add that you should set the brake with the clutch depressed or while in neutral with your foot on the break. Let off the break after the e brake is set then put it in 1st or reverse. This relieves tension on the tranny.
Old Sep 20, 2005 | 03:17 PM
cer2225's Avatar
cer2225
+1 for sure. Do it all the time...make it a habbit, its important.
Old Sep 20, 2005 | 03:36 PM
rockinbboy's Avatar
rockinbboy
wow..didn't know that. This a problem here in MD? I've been here almost 2 years and it gets cold..but not like NY cold. I'd think it would be safe to have the E brake.
The Mike's Avatar
The Mike
neutral and pull way back on my e brake. works fine.
Old Sep 20, 2005 | 04:34 PM
tabrizio's Avatar
tabrizio
Why not just put it in gear to be safe?
