Can you get the shifter out of the Gear without..
Can you get the shifter out of the gear without pressing the clutch pedal?
Today while i was driving i noticed that i was able to simply pop out the shifter out of the 4 th gear.
But then i tried it with other gears too and i could just get it out of any gear without pressing the clutch???
I was even able to bring it into "some"gears without the clutch!!
This is not normal is it??
It is scary to think that while im driving i can just hit my shifter and it will pop out of gear???
Of course, its a synchronized transmission. Not only can you get it out of gear without using the clutch, you can put it in gear. There are plenty of discussions about downshifting and rev-matching. The basis of those discussions is changing gears at the correct RPM.
Yes you can its called power shifting, you have to find the right rpms- in the Z its about 4200-4500 try it through that RPM band, I did that on a nissan test drive Z lol and it ran fine!
If you can get it out of gear while under power, you have a problem!
If you unload the tranny just so, yes you can. Not a good idea on long term though.
Bodyboarder81
Sep 21, 2015 06:23 AM
