Car shut off on the highway @ 130mph
Old Oct 12, 2005 | 10:10 PM
Jetpilot718's Avatar
Jetpilot718
Don't knock the pop charger. I have an 04, no issues. I've installed and re-installed (after cleaning it) many times, never an issue. Then again, I also know how to drive stick properly, and I do not slam the clutch in and leave it after WOT and at high speeds. Coasting is bad for any car with any intake installed for this reason alone.
Old Oct 13, 2005 | 04:26 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I had my popcharger for close to 2 years. Never had an issue. Cleaned it many times, no issues. Had my car up to 150mph, no issues. It's really wied how some people have problems and others are completely happy. Got to sell mine now because of the S/C.
Old Oct 13, 2005 | 04:37 AM
Tattude's Avatar
Tattude
Should've kept going in 5th... You only get about 500rpms from 6th gear.
I love this gear box too, never missed a gear yet and I've taken to the track a few times as well as spirited driving...?
I read this a lot though on hear?
Old Oct 13, 2005 | 06:52 AM
pj550v12's Avatar
pj550v12
I've had this happen too, and while I cant remember because I'm usually focused on other things when its happened, I wonder if this does in fact only happen when the clutch has been pressed in and the rpms drop. I feel like with the pop charger there is nothing that can really stop the rpms at ~800 after just being at 6600 and the car just shuts off. Whats scarier is when you're cruising at around 90-100 one a wet road and the car shuts off when you're in the middle of a turn with a barrier to your left and another car to your right. At that point you dont know whats going on, I thought I was hydroplaning. All I could do was say my prayers and thank the Z for a good time.
Old Oct 13, 2005 | 07:03 AM
D350Z10's Avatar
D350Z10
Thats weird i had the same problem once when i had my headers installed??? No clue i think my idle speed wasnn't accurate causing the engine and ecu to throw of timing.
Old Oct 13, 2005 | 07:13 AM
njsho's Avatar
njsho
I thought this had to do with an unshielded crank angle sensor wire?
Old Oct 13, 2005 | 07:25 AM
AZZGUY's Avatar
AZZGUY
[B] I think some of these modifications may affect the mass air sensor. I had one go bac in my 95 Maxima - I would be driving along and the engine would stop suddenly. Not a good feeling when driving the center of the expressway at 75 mph. I would just slip it into neutral and start the engine , back into drive position and keep moving. It took several trips (and $750) to the dealorship to solve the problem.
Old Oct 13, 2005 | 09:24 AM
highside107's Avatar
highside107
Is this popcharger issue just an '03 thing?
Old Oct 13, 2005 | 09:51 AM
TeCKNeiC's Avatar
TeCKNeiC
Don't tell me this now, I finally got my pop charger in and I am going to install tommorow...
Old Oct 13, 2005 | 11:34 AM
nicolaycastro's Avatar
nicolaycastro
You are better off doing a search and finiding who has been having issues with the pop charger, also as some one mentioned before you may not even get the problem, or even prevent the problem by resetting the ECU or waiting for the ECU to adjust to your pop charger.
Old Oct 13, 2005 | 01:47 PM
MeetJoeAsian's Avatar
MeetJoeAsian
buddy...after you've installed your popcharger...reset your ECU by unplugging the battery for about 20 minutes, don't wait and let your ECU adjust by driving it...just reset it and you're safe...I've never had a problem with mine
Old Oct 13, 2005 | 02:41 PM
usmanasif's Avatar
usmanasif
Originally Posted by Dream350Z
the popcharger has about 2000 miles on it. Not old at all...I should pop my hood and check how secure it is now. Thanks for the reponses guys...
Your car shut off at 130mph and you didn't even pop the hood the check what went wrong?
Glad you're safe.
Old Oct 13, 2005 | 04:30 PM
TeCKNeiC's Avatar
TeCKNeiC
I'm pretty sure after I remove the stock intake I'm going to get a "Service Engine Soon" light. Is the pedal pressing method the equivalent of unplugging the battery in order to reset the ecu?
Old Oct 13, 2005 | 04:46 PM
Nexx's Avatar
Nexx
I've reached 150+ and have thrown it into neutral many times without my car turning off. And yes, I do have a popcharger. What am I doing right?
Old Oct 14, 2005 | 07:03 AM
Dream350Z's Avatar
Dream350Z
Glad you're safe.
You know what? I kicked myself 100 times for not pulling over. Just three weeks ago I was w/ my buddy in his 305WHP eclipse doing about 120 on the highway, he redlined 4th gear, went to shift, and his motor shut off....He pulled over only to notice that his timing belt snapped. I wasn't even thinking about it at the time.
Old Oct 14, 2005 | 07:29 AM
Lerxst's Avatar
Lerxst
It's the same... I reset the ECU after the install and never had a problem.
Old Oct 14, 2005 | 07:34 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
The pedal method will reset your ECU. I've just never been able to do it. It will take longer than 20 min. for your ECU to reset if your battery is unplugged though.
Old Oct 14, 2005 | 07:36 AM
  #38
JLS2005's Avatar
JLS2005
05, with popcharger, 4000 miles, no problems. I love the whistle sound it produces at wot!!
Old Oct 14, 2005 | 08:04 AM
  #39
TeCKNeiC's Avatar
TeCKNeiC
Went ahead and installed, did the pedal pressing method to reset the ECU and opened it up for a good 30 minutes straight reaching speeds of up to 105 a few times and it's looking (and sounding) great. No stalls, no problems except for drilling holes in the plastic snorkel. That whistle is great and the exhaust note after 3000 rpms.
Old Oct 14, 2005 | 09:24 AM
  #40
plumpzz's Avatar
plumpzz
+1
