quick question: turn signal removale
Old Oct 22, 2005 | 04:19 PM
madtrixx8's Avatar
madtrixx8
Default quick question: turn signal removale
can anyone tell me how to remove the 2 rear turnsignals. i need to take the 2 caseings out. do i have to remove the rear bumper? please PM if you know how.thanks!!!!!!!!
Old Oct 22, 2005 | 09:24 PM
angelzhope720's Avatar
angelzhope720
I don't know why people don't just experiment on their own. All you have to do is pop your trunk open, remove 3 plastic covers, get the right tool and unscrew your taillights. You have to kind of yank on them. Then you reach under and replace your turn signals. Beware the space is pretty tight.
Old Oct 25, 2005 | 09:02 PM
madtrixx8's Avatar
madtrixx8
angel,
thats to remove the turnsignal bulbs, i need to remove the whole caseing. the casing that holds the turn signal bulb and the reverse bulb. anyone know what im talking about please help. thanks
Old Oct 26, 2005 | 08:51 AM
madtrixx8's Avatar
madtrixx8
still need help!! anyone know how?
Old Nov 3, 2005 | 02:29 PM
madtrixx8's Avatar
madtrixx8
bump. anyone know??????????
Old Nov 3, 2005 | 02:42 PM
Soccerprep205's Avatar
Soccerprep205
yeah i know how! PM me and i'll either send pics or explain if you haven't figured it out yet
Old Nov 3, 2005 | 02:47 PM
nicolaycastro's Avatar
nicolaycastro
I guess the best way is to remove the rear bumper completely, may be you dont have to, but thats what I am guessing. To remove the rear bumper you will be better of to search for a detailed DIY guide on how to do it. I dont know if this would be of any help since I dont remeber exactly how I did it, or where I got the info from. Ill just tell you what I remeber.
-Remove the rear tail lights completly by removing three bolts on each tail light.
-Then you have to turn a plastic piece located right under where the tailights come off, it is a very tight space, and if I remember correctly you need to use a 10 mm wrench.
-you also have to remove the splash guards, adn remove some more bolts in the bottom of the bumper.
-then in the top of the bumpre, you lift the black plastic, and the you have to kind of pull the bumper so it gets released from some clips, which hold it in place.
You could probably get the turn signals off completly just by removing the bumper partially...
Old Nov 4, 2005 | 05:22 AM
DBL54's Avatar
DBL54
i am looking for clear corners for an '03 touring package. i want the clear to be both inside the light and where it is on the front bumper. anyone know where to buy locally in MIAMI...??email me cause i wont be able to find this forum again . i am new. thanks
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
