Gettin' colder outside...check your tire pressure
Old Oct 25, 2005 | 02:14 PM
DavesZ#3's Avatar
DavesZ#3
Originally Posted by Ryan Stiles
when i said right, i meant correct location. So the FR rim always has to be on the FR, so you can't rotate the tires unless you take the tire off of the rim?
Zack
You can't rotate them anyway - different size on F/R. You can dismount them and swap them left to right.
Old Oct 25, 2005 | 02:37 PM
lightner22's Avatar
lightner22
How accurate are the TPS sensors? I filled my tires to 39 this morning and the TPS read 32. I'm sure my digital gauge on the air compressor could be off, but it is usually within 2 or 3 psi of every other gauge I have ever used. 7 seems very extreme.
Old Oct 25, 2005 | 04:49 PM
DavesZ#3's Avatar
DavesZ#3
Mine are real accurate. I have a tire pressure gauge that I use when filling my tires that is readable to ½psi. I can set them at exactly 35 psi then go drive the Z and my TPMS will read 35 on all four wheels.
BTW, my gauge is a QuickCar racing gauge. It's about $35 bucks but is worth every $$$$. I've wasted more than that over the years on cheap pencil and dial gauges that don't read consistently, and are highly inaccurate.
7psi difference seems like a problem. I would suspect your compressor gauge is off.
Old Oct 25, 2005 | 06:44 PM
lightner22's Avatar
lightner22
Me too. Its a digital gauge that is removeable from the compressor. It reads a psi or two different when it is removed versus when it is inline with the compressor. Go figure. I definitely need a more accurate gauge, but moreso for my sportbike where correct tire pressure is much more important.
Thanks for the info on the QuickCar.
Old Oct 25, 2005 | 07:36 PM
kalima275Z's Avatar
kalima275Z
subscribing
Old Oct 26, 2005 | 04:07 AM
DavesZ#3's Avatar
DavesZ#3
Here's one additional note on the accuracy of the TPMS. The manufacturer claims ±2% up to 150psi. At 35psi it should be ±0.7, so in reality the pressure should be within 1 psi of the actual amount.
If you're interested, check out the spec sheet from Schrader
http://www.schraderelectronics.com/d...older=brochure
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
