Question About Feathering
Old Nov 3, 2005 | 09:24 AM
Nismo Z33's Avatar
Nismo Z33
Default Question About Feathering
hey guys i spend the last 3 days reading all the problems, i have a question, if i was to get brand new suspension, coil overs and sway bars, would that help the feathering at all in the long run? like i wouldnt have to change tires at 20 000 KMs and so forth?
Old Nov 3, 2005 | 09:35 AM
Vamos_Rafael's Avatar
Vamos_Rafael
new suspensions is eveyrthing would be more aggressive set up...
which means harder on the car thus rubber
Old Nov 3, 2005 | 09:39 AM
Nismo Z33's Avatar
Nismo Z33
i kinda didnt quite understand what you said there? i know that the more aggresive the setup the more camber and tthe faster your tires wear. ( I had a M3 ) so theres nothing you can do to fix the feathering than???
Old Nov 3, 2005 | 09:50 AM
Vamos_Rafael
if you were to stay stock the dealer fixes the feathering issue for u
its under recall warranty bro
Old Nov 3, 2005 | 09:57 AM
Nismo Z33's Avatar
Nismo Z33
yes i understand that but does it not still keep rubbing your tires down and you have to get new ones every 10 000 Miles? iv read that in 3 posts, so im asking if i could fix that so i dont have to change tires that often, especially when your buying expensive ones all the time...
Old Nov 3, 2005 | 09:58 AM
If you have reviewed the most recent, say, 100 “feathering" posts, you know that uneven front tire wear is a compromise between superior handling and tire life. For handling, negative front camber is a must. The downside is short tire life.
Suspension alterations will change front-end alignment. The exact effect that this will have on tires is at best a guess.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
