Paint removal advice needed
Sup everyone,
Need some help. Awhile back, I messed up my driver's side fender and needed a new one. The body ship did an okay job on the fender but unfortunately I discovered excess paint on my driver's side window and windshield (I noticed my driver's side window had a rough texture and you can sorta make out fingerprints on the windshield
). It's too late to take it up with them, so my question is what product/solution should I use to remove the paint. My driver's side window is tinted so that's a consideration also. Any help would be mucho appreciated.
Removing paint from glass should be easy. I recommend an auto polish with good cleaning ability such as Prestone. Avoid solvents such as paint remover: one drop on the car surface and you're in deep kimchee.
Just get some acetone on a rag and wipe off the overspay it will be fine just dont bathe your car in it. Acetone works good at removing tar and things like that. Just dont rub your paint hard with the rag, doesnt take much. Plus hes only using it on glass anyways.
Originally Posted by JETPILOT
Clay bar... that's what is was designed to do. Remove overspray.
Respect
JET
Respect
JET
liqalu04
Jan 2, 2022 12:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
