Why did Nissan do this? Alarm/HID
Old Nov 6, 2005 | 07:16 PM
Tekwon-V's Avatar
Tekwon-V
Default Why did Nissan do this? Alarm/HID
I've been meaning to post this since the day I got the car. I am JUST NOW remembering to post it... 20 months later.
When the OE alarm goes off (or push the PANIC button), the headlights blink with the horn. Um... HELLO?!?! These are HID headlamps. Keep turning it on/off repeatedly will shorten the life, correct? If it was a halogen headlamp, I could careless.
I couldn't believe myself.
Old Nov 6, 2005 | 07:19 PM
Swiffer's Avatar
Swiffer
Well, if the alarm is going off or if you pushed the panic button, I'm sure you wouldnt mind if the lifespan of your headlights gets decreased. Atleast, if its an emergency. As for shortening the lifespan, I'm not sure how HIDs are affected by repeatedly turning on and off.
Old Nov 6, 2005 | 09:40 PM
Vamos_Rafael's Avatar
Vamos_Rafael
its called alarm = alert = danger = bad = emergency = now or never = death is eminent
so basically shorting the HID for a couple minutes for what i listed above is worth every penny
Old Nov 6, 2005 | 10:02 PM
bamyi's Avatar
bamyi
^^^^True that, even if the car has to blow its door open, I could care less if my life is at hand.
Old Nov 6, 2005 | 10:09 PM
ASTIG_Z's Avatar
ASTIG_Z
how do you activate the alarm? I havent experienced my Z being tampered with...yet.
Can you guys fill me in to how to set off the alarm without pressing the panic button...
Old Nov 6, 2005 | 10:50 PM
NTRIGUE's Avatar
NTRIGUE
Flashing the HID's can be drastically reduce the life of the bulbs. However, you ARE panicking. Bulbs only cost $150-300. They can't change the alarm to suit HID and then Halogen Z's differently (efficiency wise).
Old Nov 6, 2005 | 10:55 PM
bamyi's Avatar
bamyi
Honestly I don't know cause I never tried it, but try locking yourself inside and then unlocking your door without the key. If that doesn't work, park it in a bad neighborhood and just watch.
Old Nov 7, 2005 | 03:40 AM
abyss's Avatar
abyss
roll your windows down, lock the car...wait about 5 minutes and pull pin or flip tab (which ever the Z has to manually unlock without key) thats how I used to accidently setoff my factory alarms at gas stations when I couldn't get to my fob.
Old Nov 7, 2005 | 04:37 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
Yea, people do it to my car all the time. My car will be locked and a friend of mine will go to get in the car, door is locked, they just reach in and un-lock it. Poof! Alarm goes off! Stupid stupid people keep setting my alarm off...
Old Nov 7, 2005 | 04:54 AM
ZRiCaN's Avatar
ZRiCaN
Nothing we can do now but I agree with your complaint, why couldnt they just have it wired to the Hi-beams, just as effective as flashing the lows in an emrgency, also if you are driving duuring the day and need to flash your hi beams (headlites off) it will turn on both HID and Hi, oh well
Old Nov 7, 2005 | 04:56 AM
Santacruzslick
Veteran
I wonder how hard it would be to re-wire it so the alarm flashes your high beams?
Old Nov 7, 2005 | 01:49 PM
PunKidd's Avatar
PunKidd
I don't think you could do it via wiring and keep everything else working properly. To keep everything else working as intended you'd have to re-program the BCM to flash the other set of lights. I’m sure we could work that into our re-flash system when we get it ready for the market some time next year, if there is a real interest in it.
Old Nov 7, 2005 | 05:16 PM
The Brickyard Rat's Avatar
The Brickyard Rat
The problem that wasn't.
Old Nov 7, 2005 | 07:39 PM
lilaznxboi08's Avatar
lilaznxboi08
You can do it by leaving your windows open, then wait about 1min for the alarm to activate, with the blinking red light above your dash. then unlock your door through the window, this sets off your alarm.
Old Nov 7, 2005 | 08:09 PM
drumma022's Avatar
drumma022
I frequently flash my HIDs instead of the high eams since it grabs more attention to whoever I am doing it to. Interesting to see if it actually makes a difference.
Old Nov 7, 2005 | 08:14 PM
Gryphin's Avatar
Gryphin
trust us when we say it does^^^^
Old Nov 7, 2005 | 09:02 PM
jakesford's Avatar
jakesford
the HID's flash when i flash my highs soo...
Old Nov 8, 2005 | 02:00 AM
cwerdna's Avatar
cwerdna
Thumbs down
Yup, this is correct. Lame design which is also shared by my Maxima (which also came standard w/HIDs). If memory serves, I've also seen previous gen (pre-04) Acura TLs w/factory HIDs do this too.
Old Nov 8, 2005 | 04:08 AM
Santacruzslick
Veteran
What if your car has HID low AND high beams. Like a BMW. Then what?
Old Nov 8, 2005 | 05:56 AM
drumma022's Avatar
drumma022
Same with the 06 350z headlights - when you flash somebody when your lights are off, it flashes the HID on/off. I don't see it as a poor design, when many of the new cars do the same thing. I'll still continue to use the HID flash as a warning device.
