warmup sequence on my Z
Old Nov 8, 2005 | 12:54 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
Unhappy warmup sequence on my Z
I have a few questions I can't seem to get straight answers. I have a habit of warming up the Z before I go anywhere and I notice that when I do I only see the exhaust morning steam or smoke come from the passenger side only. I can feel the heat coming only from that side also but the driver side seems cold in the morning.....what gives I have the Crawford Hi-flows with a Invidia g200 true dual exhaust. Is this normal for my car or should I be concerned since I thought it would or should smoke from both sides but it seems not....
Old Nov 8, 2005 | 12:59 AM
lilaznxboi08's Avatar
lilaznxboi08
hmm seems kinda weird... i have no idea
Old Nov 8, 2005 | 02:29 AM
I can't be positive about your situation, but we have seen high-flow cats where the material inside has collapsed partially blocking the cat.
Old Nov 8, 2005 | 07:32 AM
ANXIOUZ's Avatar
ANXIOUZ
If you only get smoke and heat on one side then something seems to be blocked/leaking.
Old Nov 8, 2005 | 10:58 PM
steela2110's Avatar
steela2110
Dude I have the Non resognated Helix test pipes and have the G200 exhaust as well. I had the same problem until I got the emanage to help out the stock ecu. Your engine is most likely running to lean
Old Nov 9, 2005 | 08:32 PM
AmyCroft's Avatar
AmyCroft
Question Got your message Tuesday - PM me your Cell Number
Associo,
PM me your Cell.. ( My Cell Said - Not Allowed?? )
Have you called the guy that sold you the Crawford Cats? Did he have a problem? I'm thinking driver's side is Coked up - Plugging.
After the car is warm - you should have equal pressure ( At exhaust tips) - since the G200 Invidia has separate paths and no cross over pipe.
Amy
Old Nov 10, 2005 | 12:47 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
Amy I don't think my a/f is off with my Plenum spacer, Exhaust and Hi Flow's or I am wrong. I will be adding my intake also to the mix so I am confused. I had to take my car to a muffler shop to install me hi-flows since Tony's lift was used. I think next time I will wait for his help than take it somewhere......
zpeed350
Nov 13, 2005 02:54 PM
syf0n
May 11, 2005 08:22 PM
D'oh
Oct 24, 2002 10:51 PM
