How high is your clutch engagement point? (Stock)
Old Nov 17, 2005 | 07:19 PM
itburns's Avatar
itburns
Originally Posted by lw3
Will lowering the pedal help me from hitting my knee against the steering wheel cause im 6'0. Will the dealer do this for you?
Put your seat all the way back and raise the adjustable steering wheel higher first. Lowering the clutch height will give you another inch or so.
Old Nov 17, 2005 | 07:22 PM
itburns's Avatar
itburns
Originally Posted by gsazabi
OK here's something new,
Since my new clutch's engagement point is too high, i decided to
do a test and try stalling the car on purpose by
putting it into 1st gear from stand still and let out the clutch.
Guess what, it's IMPOSSIBLE to stall my car!
I can get the car moving from standstill just by using my clutch,
fully released without pressing gas!!!!!!
I tried so many times to stall the car, and it looked like it was
going to die due to no gas input, but when the clutch was fully released
it still kept on going!!!
Mind you the ground was completely FLAT.
Only time I managed to stall the car was when I actually had
my break pressed on firmly while releasing the clutch.
man WHAT THE HELL
Try this when your engine is hot and your idle is low.
Old Nov 17, 2005 | 07:23 PM
r26's Avatar
r26
i lowered my clutch and everything is fine
Old Nov 20, 2005 | 02:52 PM
albatross83's Avatar
albatross83
So I wasn't the only person with this ridiculous high engagement point!
En-GLaived, is your 06's clutch also light? I believe they installed the
latest clutch on mine, and it was pretty damn light clutch.
I just got my clutch replaced too, and it's light as hell. I kept asking if that was normal, but they just shrugged. I didn't really push it becuse they had had my car for a week and a half, and I just wanted it back so I could install my antisway bars that had been sitting around for a week.
But the day after I got it back, I powershifted into 2nd at only 4k, but it slipped like a @$#% when I floored it, whereas before it would chirp the tires and go. I could smell burning clutch after that, and needless to say I was pretty pissed, but I haven't been able to reproduce it. So I'm not sure if it was just a fluke, or break-in, or what. I've never heard of break-in on a clutch though? As far as I know, they just get worn more and more until it's time to get a new one.
Old Nov 20, 2005 | 04:43 PM
lw3's Avatar
lw3
My seat is lowered to the floor and all the way back. My steering wheel is on the highest setting and I still bump my knee when shifting.
Old Nov 21, 2005 | 05:37 PM
eat rice z33's Avatar
eat rice z33
adjust your clutch! its the easiest and best thing ive doen to it!!
Old Nov 21, 2005 | 06:47 PM
MyZ4U2C's Avatar
MyZ4U2C
Im one of the "lucky ones" that had to have a new tranny and clutch put in my '03. It was like learning how to drive all over again when getting it back. I have to let the clutch almost all the way out...on the flip side, my car has never seemed quicker.
Old Nov 22, 2005 | 05:56 AM
arejohn's Avatar
arejohn
Default right foot
Originally Posted by mavtais
The Z clutch forces you to drive properly: Drive with your left foot on the kick plate.
When I drive with my left foot on the kick plate, do I steer with my right foot?
Sometimes I think my clutch is engaging at different points and my shifts are not smooth. Is this what you are experiencing?
Old Nov 25, 2005 | 03:38 AM
daequitz's Avatar
daequitz
I just got a new stock clutch and flywheel installed on my 05,
and the clutch starts to engage when the pedal is almost released all the way.
Basically it engages like an inch or half inch before it's fully released.
Does that sound about right for stock? When I first got the car engagement
point was still damn high, but I don't remember being this high.
How are your stock engagement points?
Any way to lower the engagement point?
I've already read the thread about turning the **** on the pedal,
but it seems like it only adjusts the pedal, not the engagement point itself.
FWIW, mine was way high after the tranny was replaced at 6800 miles. I took it back in @ 8k miles and they adjusted the disengagement point back down toward the floor. The dealer wouldn't buy into the idea at first and so we went out to the lot and got into a new Z. Big diff. It's not perfect, but much better. I've tried various seating postions. I still occasionally pop the damn thing from 1st to 2nd.
There is a range of adjustment as specified by Nisaan, however, I was told it's not a whole lot. The dealer would not adjust mine beyond this "window". As I was told; apparently many Z drivers don't take the pedal all the way to the floor and Nissan thought that could be one of the contributing factors to early clutch/transmission problems. Oh, and I wasn't charged for the adjustment........
Old Nov 25, 2005 | 12:09 PM
blackpitbull's Avatar
blackpitbull
I just bought a 2003 2 days ago and last night engaged the clutch from a stop 100 times to get a good feel for it. It engages about half way without a doubt.
Old Nov 25, 2005 | 12:28 PM
texasGJ's Avatar
texasGJ
i just adjusted my clutch last night, according to the thread that was linked to above...
it took about 10 minutes. the only hard part was fitting down in there to make the modification. anyhow, my clutch is about even with the brake pedal... SO much easier to drive now!
Old Nov 26, 2005 | 05:05 AM
daequitz's Avatar
daequitz
Gonna try to better adjust mine too.
Old Nov 26, 2005 | 07:24 AM
AZZGUY's Avatar
AZZGUY
NO!!!! Keep your right foot on the floor. Steer with your hands.
ablaine
Nov 29, 2016 10:13 AM
Tochigi_236
Sep 27, 2015 03:40 PM
