how bad is it to drive without plastic under belly engine cover.
Old Nov 21, 2005 | 07:31 PM
gimpster621's Avatar
gimpster621
Default how bad is it to drive without plastic under belly engine cover.
screws came off and i was dragging my plastic cover. screwed it back on but its funky looking and scrapes on dips and bumps. anyone drive without it?
Old Nov 21, 2005 | 07:34 PM
Vamos_Rafael's Avatar
Vamos_Rafael
ur in socal
rain and stuff will be a rusting problem but socal doesnt rain much...
so...
imo not much prob...
Old Nov 22, 2005 | 04:41 AM
SkiTTlez's Avatar
SkiTTlez
i cut off the front half since i didn't want to drill holes in my new bumper. just gets a bit dirtier, but then again i clean my car like twice a week so who cares? it is just for protection from stuff flying up into your engine bay and such. not going to cause any rusting or whatnot.
Old Nov 22, 2005 | 05:41 AM
The splash pan is there to protect delicate items such as these oxygen sensors and wiring. Get one.
Old Nov 22, 2005 | 05:43 AM
Vamos_Rafael
good call davidv
Old Nov 22, 2005 | 06:23 AM
cessna's Avatar
cessna
Plastic wont help against rusting/corrosion.....
Old Nov 22, 2005 | 08:21 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
It's not there to protect anything.
It's not going to stop rust, salt water etc.
It's not supposed to try and keep it clean.
Look at the picture above, notice how flat everything is and it would be flatter still if the pictured Z had the stock exhaust. The belly pan is part of the standard 350Z aerodynamics package to help minimize turbulence and smooth out air flow under the car.
You don't NEED it, and you may not notice if it's gone, but if you are looking to get the most out of your Z leaving it off is not really the answer. If it were me, I would the hardware store and get the 10mm bolts and put it back on.
Chris
Old Nov 22, 2005 | 12:13 PM
Netko350Z's Avatar
Netko350Z
Areodynamic lift...
Old Nov 22, 2005 | 01:16 PM
jakedajewel's Avatar
jakedajewel
i finally got my 1st oil change and took it to a local Nissan dealer (Ontario Nissan - they suck btw, dont go there).
as i was waiting (2 hrs!!!), i saw the mechanic unscrew the plastic bottom cover and bent it, to get a better feel for the oil filter.
I asked the mechanic if i can take it off, he advised not to, since it protects the engine from certain things (i imagine water and dirt).
WHen i saw him bend the plastic cover, i couldnt help myself get a lil upset, since he was bending it with no respect to my vehicle.
Old Nov 22, 2005 | 01:29 PM
Fletch69z's Avatar
Fletch69z
It's for aerodynamics...
Old Nov 22, 2005 | 01:35 PM
Jiffy Lube will do the same (note the motor oil all over the front passenger side). They pull a few bolts out of the splash guard, pull it down, the drain the oil and remove the filter: oil splashes everywhere. Pride and auto service seem to be contradictory terms. While the splash guard was off, I scrubbed it at the car wash. At least that's pretty clean.
Old Nov 22, 2005 | 01:44 PM
zzz350's Avatar
zzz350
I think it is funny that when you take it to an oil changing monkey, they want an additional charge to deal with it. Then all they do is bend it out of the way, so WTF is the extra charge for? Besides screwing you.
Old Nov 22, 2005 | 01:52 PM
bmxox's Avatar
bmxox
It doesnt hurt anything to not have it.
And about bending it remove the filter, It doesnt hurt it to be bent, its very thin plastic, try working in a garage and change oil on 30 cars a day that all have a plastic or steel cover (suvs), you'd be bending them if you could too.
Old Nov 22, 2005 | 01:58 PM
cessna's Avatar
cessna
Dude its just a plastic piece!!!! If you start losing it for that,..Geez, I'd hate to see you get into an accident!
Old Nov 22, 2005 | 02:03 PM
ANXIOUZ's Avatar
ANXIOUZ
I have mine off. It was scraping on something whenever I pressed in my clutch so I removed it. I took it to the dealer twice to have them look at it and they didn't do squat both times.
I want to get another one though for piece of mind. I believe they cost around $100. Ugh.
cessna's Avatar
cessna
Get sheetmetal skid plates!!!!
Old Nov 22, 2005 | 07:55 PM
oren's Avatar
oren
ive been driving without mine for about 6 months, mine broke when i hit a raccoon havent had any prbs yet
Old Nov 22, 2005 | 08:33 PM
bigk's Avatar
bigk
I took mine off because its just a pain in the A$$ to take off everytime I change my oil. None of my old cars had them, so I'm not worried about having it off.
Old Nov 22, 2005 | 08:48 PM
HyperSprite
Mad Scientist
Why do I bother
Chris
Old Nov 22, 2005 | 09:40 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Its about $80 bux to replace...
It is mostly for aero dynamics...
Tony hasnt had his on since he put on his first aftermarket bumper...
Mine have always come out and dragged, so I cut off the front part that flapps when you dont have the screws in, and left the rest on...
The lower engine cover doesnt go as far back to cover the O2 sensors in the cats that harness clip onto the trans bracket...
A fedex truck tire ripped those out from my car once too...
