Increasing Gas Pedal Resistance
Old Nov 27, 2005 | 02:07 PM
punish_her's Avatar
punish_her
Originally Posted by TeCKNeiC
Thanks for the helpful responses, especially the crap about sharp knives. Thank god we have people on the forum that are great with analogies or I would never get any help with my Q's. Unfortunately the 03 350Z manual is "TnA". I did find the spring and the screw to remove it but I have no idea where to get a replacement spring with more tension. At 6'3" 225 with more of my height in my legs pushing the pedal and holding the pedal is a particular position is causing a pain in my upper thigh. Maybe I may be a half an inch too tall.
The 03 and 04 should be identical for the manuals. 05 is where it changed in some of the electronics. Try my suggestion of the inner spring, it may help increase your tension where you like it. Most auto parts storers have varrious types pf springs, if you get one to long just trim it.
All else fails, just amputate your right foot. You'll loose about 3 inches on you pedal leg J/K
Old Nov 27, 2005 | 02:17 PM
twinship's Avatar
twinship
Don't worry about the "experts" who have nothing better to do than take cheap shots at others' preferences.
So where exactly is that spring?
If you end up replacing it with a stronger one, be sure to post details.
Old Dec 12, 2005 | 12:25 AM
TeCKNeiC's Avatar
TeCKNeiC
I will grin and bare it. Maybe get a G later.
Old Dec 12, 2005 | 12:26 AM
TeCKNeiC's Avatar
TeCKNeiC
BTW Thanks for the help Mike.
Old Dec 12, 2005 | 06:05 AM
maxpowers's Avatar
maxpowers
I'm not 6'3 but I find the same thing becuase I have long legs. On extended trips I feel most of my effort is trying hold my foot up. In a relaxed state, my foot tries to push the pedal in about 80%.
For those of you making fun of us, this isn't about trying to find some little thing on the car to bit$ch about, after about 2-3 hours, my right leg actually starts to cramp up!
On a side note...........I also hit my knees on the seat in front of me on airplanes................and I have to stand up to let people get past me at hockey games (for US readers substitute hockey for football).
Old Dec 12, 2005 | 06:42 AM
zillinois's Avatar
zillinois
Not sure if you guys know this or not, but the Z does not have a direct mechanical connection between the throttle and accelerator pedal. It has drive-by-wire. When you press the accel pedal it sends an electronic signal to the throttlebody. There may be some kind of spring regulating pressure of the accel pedal, but it may be linked to the drive-by-wire system. Just something to consider before changing things. The d-b-w system works on intent too, so it may not help putting stiffer spring in. It may feel better, but still drive the same. It is a radically different system than almost anything that came before it. I wish I had more helpful advice, but at least its a place to start.
Old Dec 12, 2005 | 09:20 AM
twinship's Avatar
twinship
Good to know, thanks.
Even with D-B-W there must be a spring (or?) that regulates the pressure required to depress the gas pedal. Just have to find it and figure out a way to increase its strength!
Old Dec 12, 2005 | 04:26 PM
maxpowers's Avatar
maxpowers
Agreed. Having said all of this, I've had worse experiences with cars not designed for the tall. In my old '90 Integra (two cars ago), my seat position required me to stretch for the shift ***. Sort of takes the sports car feel away. In my Z the shift *** sits perfect.
Old Dec 12, 2005 | 04:40 PM
solarscar's Avatar
solarscar
All i get is **** N Azz when i try to download the manual. The site is down.... ARgg.... Can someone email it to me? I can put them on my server for everyone else to download. My email is adam@evolimports.com
Thanks... Adam
Old Dec 12, 2005 | 05:53 PM
reptile718's Avatar
reptile718
I drove my Z home from Ohio about 6 1/2 hour trip and had the same leg crap issue, also I agree with the rest of you guys pedal is too touchy and if I dont give it enough gas it tries to stall, its hard trying to find a happy medium. I have a 95 Mustang with the 5.0 and it drives completely opposite, sux when you switch cars a lot. If someone finds a solution please PM me, thanks!
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
hulkout
Apr 28, 2017 09:00 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
