Very strange problem in my Z, traction goes off
Old Dec 16, 2005 | 08:18 AM
Reggi914's Avatar
Reggi914
Default Very strange problem in my Z, traction goes off
I was driving on the highway once and i had to sort of stop short because someone infront of me did the same. I noticed that the "vdc off", "slip", and "brake" lights all came on!!! I pulled into a gas station and there was some ice on the floor so i wanted to see if my vdc really just went off or perhaps it was just a fuse/ligh problem. My vdc really was off!!! I turned the car off and on and the problem was fixed. This happened to me again since this, once when breaking hard and once when accelerating hard.
Has this happened to anyone?
Old Dec 16, 2005 | 08:54 AM
DavesZ#3's Avatar
DavesZ#3
Check your brake fluid to make sure it's not low. Other than that, a couple of people reporting similar problems have brought it in to the dealer who eventually determined that the computer was whacked and replaced it.
Old Dec 16, 2005 | 09:07 AM
MustGoFastR's Avatar
MustGoFastR
Yeah, sounds like there is a fault in the sustem. It is designed to shut down completely if it malfunctions. Does your ABS still work ok?
Old Dec 16, 2005 | 01:06 PM
imseksy's Avatar
imseksy
i dont have VDC but dont most people want their VDC off for horsepower loss purposes?
Old Dec 16, 2005 | 01:22 PM
LBCz33's Avatar
LBCz33
that sounds like some sort of computer issue, possible bad connection with the battery. the only time i have seen that type of thing is when a vehicle i was driving had a battery that died while i was driving. I've heard that when something in the system malfunctions all of those prominent warning lights appear and the vehicle goes into a "safe mode" of sorts or simple shuts down... I would have a dealer check it out just in case...
Old Dec 16, 2005 | 01:48 PM
LIdrew's Avatar
LIdrew
When was the last time you had your brake pads done?? I had teh same thing happen on my Z and it just needed new brake pads. Had rotors resurfaced too
Old Dec 16, 2005 | 03:11 PM
Reggi914's Avatar
Reggi914
How would that be the issue? I never had my pads replaced. Or at least i dont think i did, who knows what the dealer does for those "service checks"
Old Dec 18, 2005 | 11:43 AM
LIdrew's Avatar
LIdrew
How many miles on your Z? I am 99% certain it just needs new brake pads.
Old Dec 18, 2005 | 01:04 PM
3rdgenguy's Avatar
3rdgenguy
is the brake fluid low?????? add some just for the hell of it and do another panic stop
Old Dec 21, 2005 | 06:14 AM
Jonathan Allyn's Avatar
Jonathan Allyn
Its the brake fluid. Same thing happened to me and once I added the fluid all the error codes went away...
Old Dec 21, 2005 | 06:35 AM
captj3's Avatar
captj3
Chances are if your brake fluid is low you need new pads. There is no reason to add fluid unless you have a leak. If you have to add fluid make sure when you have your brakes done they remove some fluid before they push the pistons back in the calipers. I say this because brake fluid will spill all over by the master cylinder. Brake fluid is a great paint remover if lefton to long. Most dealers won't clean it like you would.
Old Dec 21, 2005 | 07:42 AM
Kolia's Avatar
Kolia
+1
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
