TCS or VDC? Difference?
Old Jan 13, 2003 | 01:54 AM
Red350Z's Avatar
Red350Z
Default TCS or VDC? Difference?
Just wondering what the difference is between TCS and VDC. My enthusiast has TCS, but not so sure what the MECHANICAL difference is between these two systems, if any. Thanks for input
Old Jan 13, 2003 | 05:56 AM
mickey's Avatar
mickey
Default See existing discussion
Search the forum.....
https://my350z.com/forum/showthread.php?threadid=612
"Seach" is such an under rated tool.
Regards,
Old Jan 13, 2003 | 10:19 AM
Red350Z's Avatar
Red350Z
Default Re: See existing discussion
Originally posted by mickey
[B]
............I tried "Seaching" as you put it, but didn't find the thread you found regarding mechanical differences. Thanks
"Sarcasm" is an overrated action.
Old Jan 13, 2003 | 01:10 PM
Alang's Avatar
Alang
Quick answer:
TCS - Traction control - cuts power from the engine when wheel slip is detected - The infamous 1st to 2nd gear "bog".
VDC - Vehicle Dynamic Control - monitors acceleration/deceleration and yaw rates along with wheel slip. Using the brakes (individually if needed) attempts to keep the car on its intended course. Sounds like clicking from the wheels during high G cornering.
Note: these will work together thus you might get both braking and power cuts at the same time (assuming you have both systems).
OK guys, is this right?
Old Jan 13, 2003 | 03:08 PM
WayneTN's Avatar
WayneTN
Originally posted by Alang
Quick answer:
And, correct me if I'm wrong. You keep some power on to make it all work. Right?
WayneTN
Old Jan 13, 2003 | 03:28 PM
Red350Z's Avatar
Red350Z
Thanks for the great info!! That's exactly what I was looking for!
MAsSIVrOOM
Oct 20, 2023 10:50 AM
loudtoyz
Apr 6, 2023 04:52 AM
