Problem Please Help!!
Old Jan 23, 2006 | 05:26 PM
hcwlsu's Avatar
hcwlsu
Question Problem Please Help!!
My 2005 350z has broken down two times in the last week and the dealer can not figure out what the problem is. The car just seems to shut down while running, like the car is going into fail safe mode. I had the crank shaft sensor go out twice already and it does the same thing. The car jerks, the RPM's jump and the car dies. It did not set off the CEL, so there is no code. The car will not start initially after the car kills, but if I turn it off and let it sit for about five minutes it starts right up with no problem. The dealer checked the sensor this time and stated that it is not the problem. I don't have any aftermarket parts under the hood. The dealer is now leaning to my aftermarket stereo which includes a stereo, EQ, one amp for the front components a basslink behind the driver seat and a Viper alarm. All of the stereo equipment is getting its power from the battery except I do have a small line driver spliced into the cig lighter in the back. I also have my radar detector wired into the front mirror. Anyone have any suggestions to what could be causing the problem. I just don't believe the stereo is the problem.
Old Jan 23, 2006 | 05:30 PM
rockinbboy's Avatar
rockinbboy
There are some people who had their cars shutdown....but I believe that is because they had an AEM intake, specifically the popcharger. Do you have have any mods such as an intake?
Old Jan 23, 2006 | 05:44 PM
hcwlsu's Avatar
hcwlsu
Nothing about the engine, exhaust or Intake has been modified. All Stock
Old Jan 23, 2006 | 06:02 PM
ohw's Avatar
ohw
"... five minutes it starts right up ...", sounds like heat related. It's not likely the stereo or detector is causing the problem. Assuming your car is still under warranty, you should eliminate the stuff in question by disconnecting the detector, pull the fuse from the cig lighter and the stereo and take it back to the dealer and let them figure it out.
Old Jan 23, 2006 | 06:09 PM
Luis_23's Avatar
Luis_23
Old Jan 23, 2006 | 06:44 PM
J3rzeyFlip's Avatar
J3rzeyFlip
go to another dealer or have nissan send in a proffesional!
Old Jan 23, 2006 | 07:51 PM
Ztalker's Avatar
Ztalker
where was your Z when Katrina hit Luisiana?
Old Jan 23, 2006 | 07:54 PM
hcwlsu's Avatar
hcwlsu
In a nice dry garage.
Old Jan 23, 2006 | 08:06 PM
Ztalker's Avatar
Ztalker
i would check the Mass Air Flow sensor first, the starter solenoid next.
Old Jan 23, 2006 | 08:30 PM
rolling's Avatar
rolling
Untill the waranty is up its not Your problem, you paid for the warranty..
i know i got better things to do than try and fix my car when i should be Driving it!
let them figure it out and if they cant, lemmon law that sucka!
Old Jan 23, 2006 | 10:18 PM
thezedsled's Avatar
thezedsled
+1
And set at least one of them on fire...
Old Feb 10, 2006 | 07:55 PM
tigga09's Avatar
tigga09
Default Problem Please Help!!
Hello, fellow z owner here. A similar problem has happened to my Z and like in your situation the service department could'nt figure it out. I would like to know the outcome of your particular situation and what the service peeps did to fix it. Any help would be deeply appreciated. Thanks.
tigga09
Old Feb 10, 2006 | 11:10 PM
ChuckGZ's Avatar
ChuckGZ
here's what you do: buy two 5 gallon gas cans, fill them up, and put them in your trunk. then drive your Z through the dealership's front window, get out of your car, dump gas all over the showroom and your own vehicle, and burn that ***** down!!! I hear that it worked for one guy in orlando last week.
Old Feb 11, 2006 | 01:09 AM
vitalya_af's Avatar
vitalya_af
ECU???
I don't know what to think......
Old Feb 11, 2006 | 03:54 AM
Z_Driver's Avatar
Z_Driver
Master
Originally Posted by vitalya_af
ECU???
Yeah, I was thinking that too. It should be easy enough for them to reflash that turkey.
Good luck .... let us know.
Old Feb 11, 2006 | 04:06 AM
JRinTXrog's Avatar
JRinTXrog
I agree with OHW, iliminate your stereo and see if it still happens. If it does than you can sure tell Nissian they are full of it.
Old Feb 11, 2006 | 06:39 AM
zdotcom's Avatar
zdotcom
I had a similar problem with my 00 maxima. Only difference was it would start up after about a minute. Once I replaced the MAF sesnsor no more problem.
Old Feb 11, 2006 | 11:43 AM
Fletch69z's Avatar
Fletch69z
That's weird.
Old Feb 11, 2006 | 01:50 PM
hcwlsu's Avatar
hcwlsu
Tigga09,
They kept my car for three weeks and could not get it to replicate the problem and they said they could find nothing wrong with it, so I picked it back up. I have been driving it for two weeks now and it has been driving fine. I believe the car has a problem with the ECU or the crank position sensor was not tight causing the problem????? Who knows. If it happens again I will just take to another dealer. I love my Z, but it has been unreliable. I will never buy another Nissan again. My car has left me stranded five times in one year and the service is horrible.
Old Feb 11, 2006 | 02:11 PM
Manjot's Avatar
Manjot
Sorry to hear that
