Are the RE040s really this bad? and how I almost crashed...
Old Jan 25, 2003 | 07:23 AM
qirex's Avatar
qirex
Default Are the RE040s really this bad? and how I almost crashed...
I was driving my wife to work this AM, there no traffic and we're coming out of the holland tunnel. Theres a LONG curve that loops around onto canal street.
Normally I take the tuurn kinda fast. However I was hung over, so i took my time. Going 20mph. The temp this am in NYC was much better ~30 degrees.
In the middle of the turn with NO warning, the rear end steps out..NO VDC...no slip light...nothing.
Lucky for me I happened to have both hands on the wheel and was able to quickly countersteer without overcorrecting. Thankfully the VDC stayed off. Normally, when the rear steps out and I see that SLIP light, i never countersteer - I let the computer do the work.
So I'm starting to agree with you guys when you say the tiures suck. The tire pressure was 38psi on the rear which is acceptable pressure. I'm not sure that they may have been *warmed* up as we'de only driven 5 minutes and I know that pressure and temp while related - there's stioll a diff btw the tire temp and ambient temp to be considered.
SO the moral of the story I think is that when you see that ICY indicator on, watch out! Even if its decent (anything above 20 is decent compared to the last week on the northeast) outside. I never remember having these probs when it was still 50s...lets let the cali and florida boys sound off on this issue!
Old Jan 25, 2003 | 07:47 AM
Intrepid's Avatar
Intrepid
People, DUMP the CRAP tires that came with your Z and get yourself a decent set of tires! Nissan should be ashamed for putting such garbage rubber on the Z, especially in colder climates. In fact, I'll go as far as to say that it's negligent to do so and sell the car in NY and other colder climates.
See for more tire details and alternatives:
https://my350z.com/forum/showthread....ighlight=tires
Old Jan 25, 2003 | 12:18 PM
mcclaskz's Avatar
mcclaskz
The RE040s seem to be especially bad at low radius turns. I was drifting all over the road at the "tail of the dragon". Shred these as soon as possible, upgrade the wheel width and get some new rubber. Personally I'm gonna go w/ 18" silver Volk te37s and Kumho MXs.
Old Jan 25, 2003 | 01:20 PM
BFG10's Avatar
BFG10
I couldn't agree more about the 040's. Not good, especially in cold temps. I've felt that rear shift way out on my a few times, as well. I'm going to go with the Pole Position S-03's. Only thing is they are made by Bridgestone too, which kind of bothers me.
Old Jan 25, 2003 | 02:00 PM
lemans's Avatar
lemans
I don't know if all brifgestones are bad(or even ours). What I know is at the LA auto show the Ferrari that costs almost 900K had bridgestone tires on it. I am in the middle of GA and so far doing okay with tire handling in our current cold spell. Not attempting to win any races though. Just be careful in the bad weather. I prefe Michelins and will put them on hopefully after I wear these stock tires out. That is assuming I don't encounter the problems I am hearing about.
Old Jan 25, 2003 | 03:14 PM
JonsilvZ's Avatar
JonsilvZ
To all the Z owners with stock tires. You have to warm the tires in cold weather. At least 20mins of driving, not idling
Old Jan 25, 2003 | 05:42 PM
xXx's Avatar
xXx
I had S-03's on my Supra and they stick very nicely. Great dry and wet traction tire. I'll probably get the same when I get rims. I really want those SF Challenges to come out.
Old Jan 25, 2003 | 07:35 PM
wildone_106's Avatar
wildone_106
So lets make a new thread.."How to survive the first 20 mins while your tires warm up" huh...thats a 20 min window where u better not dare exceed 25mph (by some accounts) or risk ur life? this is worrying...
Old Jan 25, 2003 | 08:00 PM
ares's Avatar
ares
Veteran
Its not that bad... and it doesnt take 20 minutes either. 5-10 should do fine.
as for gripping power, I just drag raced 10 times on tires in 35degree weather. while traction was very bad, there should not have been any problem with that kind of power on the street. Im guessing a little bit of ice or pebbles in the road. maybe a little extra power by accident?
the tires do indeed suck, but I promise the car has 10times more traction than other cars Ive driven. just realize that you cant do andretti style driving till the tires are warm, otherwise as was suggested, grab some new tread.
Old Jan 25, 2003 | 11:48 PM
qirex's Avatar
qirex
Chitownz,
another pork dumpling, please
Old Jan 26, 2003 | 01:17 PM
JonsilvZ's Avatar
JonsilvZ
Today I was taking a cruise. My tires(stock) were fully warmed up. I was at a stop light, I started to accelerate lightly at first up to 15mph or so (was on 1st gear) then I pressed it 3/4 way. I started to fishtail! on smooth pavement. No debris clean. Damn my car has power! By the way I was on manual mode.
Old Jan 26, 2003 | 08:04 PM
ares's Avatar
ares
Veteran
the tires can get squirrely in first through the whole band. but at 3/4? I think you were closer to full throttle than you realized.
Old Jan 27, 2003 | 06:20 AM
WashUJon's Avatar
WashUJon
Default Re: another case of the know-it-all knowing SH*&
Originally posted by chitownZ
just like the pig viruses that said "sure you can put the 6MT touring wheels on the AT touring," (WRONG!) the know nothings are back with their bridgestone 040 suck..blah...blah..blah!
the tires are fine, unless its cold and they have not had a chance to heat up, AKA you have not driven a few miles!
why professor do u say that? cause they r a summer tire and when summer tires are cold handling sucks, but only the first few miles or so, ya know, until they heat up. try basic chemistry and engineering to find out why tires grip better as they warm up!
up until the winter months, my tires have been rock solid. now that its cold, temps between 5-20 degrees, they are a bit twitchy. when they r cold, the first few miles, i am careful, until they heat up, sometimes in the early miles of a morning drive the rear end swings out, i just watch my speeds until the tires warm up, then its ***** to the wall perfect. haven't you windbags ever listened to a nascar broadcast, you always hear drivers talk about running badly on cold tires, trying to warm them up, etc...gee, guess u know more than a professional race driver
the tires are fine, sure there are better ones, there will always be something better than what u have, so if u want them, buy them, but know why something happens before you open your mouth and release your stench you gasbags!
Speaking of know-it-alls...
qirex already said his tires weren't cold.
Old Jan 27, 2003 | 09:58 AM
sbkim's Avatar
sbkim
You guys are really starting to scare me with all these posts about losing control. Thank god for VDC. I probably won't be here today if it wasn't for active handling (VDC for the C5)!
What is the recommended tire pressure for the z? 38lbs seems awfully high. I am running 28lbs in the rear for my C5 and the recommended pressue is 30lbs. It seems like lower pressure allows a bit more traction.
On a side note, recently got the Kumho's for the rear (originally had Pilots) in 295/35/18's and so far I am fairly impressed by ride/handling. These were about 1/3 less than the Pilots.
Old Jan 27, 2003 | 11:43 AM
Vlad's Avatar
Vlad
Default Re: Are the RE040s really this bad? and how I almost crashed...
I can't believe people still bringing up this topic! It was agreed over 100 times that stock tires SHOULD NOT be driven at cold temperatures. They are summer tires, so compaund totally loses it's qualities at negative temps.
Driving them at 30 is like sticking your fingers into power outlet, and then be suprised you've got electroshocked. Or jumping from 10th floor and be surprised that you broke every bone (if you are still alive).
No surprise for me here. Get winter tires, or at least some A/S if you don't see snow.
Old Jan 27, 2003 | 04:37 PM
alex30327's Avatar
alex30327
I totally agree! These RE040's are horrible in cold weather. I'm in Atlanta (25 degrees out), and am sliding all over the road. Its been kind of fun because I can kick my back end out in turns with ease, or even while backing out of the driveway! I'm upgrading to a real tire a soon as I can (TS-1 toyo).
Old Jan 27, 2003 | 10:19 PM
apex locator's Avatar
apex locator
i'm glad i live in CA....i've always liked the re040....they r awesome tires
Old Jan 29, 2003 | 08:47 PM
Subw00er's Avatar
Subw00er
We should start a class-action suit. Anyone here a lawyer?
The tires really are dangerous, and especially life-threatening in very cold/wet/snow conditions. they should have given me a tire that had acceptable cold weather characteristics.
