leaving clutch in?
Old Mar 26, 2006 | 10:35 PM
skeleton jack's Avatar
skeleton jack
A friend of mine blew is tranny when he got rear ended.
thats funny when taken out of context.
Old Mar 27, 2006 | 03:31 AM
Kolia's Avatar
Kolia
You're a sick person !
Old Mar 27, 2006 | 03:40 AM
Mike Wazowski's Avatar
Mike Wazowski
LOL at this thread
Old Mar 29, 2006 | 02:31 PM
zedated's Avatar
zedated
I have a contrary friend who insists that holding the clutch in is acceptable, despite all the expert advice that says that doing so wears the throwout bearing. The 350Z Owners Manual states clearly that you should put the tranny in neutral and release the clutch. My friend contends is that manufacturers know that people do this (hold the clutch) and have developed sturdier bearings to compensate. Fwiw, he got his information from an article about motorcycle clutches. I know nothing about motorcycle clutches, so I can't say if they are comparable to car clutches or not. I would think the forces acting on car clutches are *much* greater. Anyway, does anyone agree or disagree with my friend and why? Thx.
Old Mar 29, 2006 | 02:42 PM
zedated's Avatar
zedated
Originally Posted by highside107
I've also heard another reason for leaving it in neutral rather than clutching when you're at a stop light regarding getting hit from behind by another car. I didn't quite understand the explanation; has anyone on here heard of this as well?
In this scenario, it is good advice to disengage the engine, whether by holding the clutch or shifting to neutral. This will prevent damage to your drivetrain. Also, when you see that you are about to be rear-ended, release the brake. This allows your car to move with the impact, absorbing some of the energy and hopefully reducing whiplash injury to you. After the impact, press the brake again to stop your car from moving. Naturally, you should have left room between you and the car ahead to allow for this contingency. If not, you will probably hit the car ahead of you. Even so, the person who hit you is responsible for both.
Old Mar 29, 2006 | 04:16 PM
Penguin's Avatar
Penguin
Holding the clutch in does not wear it out. I have had three cars with clutches. The first car had 110,000 miles original clutch. My current truck has 170,000 miles and original clutch. My Z only has 20,000 miles and I drive it just like the others. As long as the clutch in fully disengaged, no damage is done. If you are on a incline or a hill and you use the clutch half way in and a little gas to hold the car in the same spot and not use the brake, then you will really wear the clutch.
Old Mar 29, 2006 | 06:15 PM
skeleton jack
Are you kidding? Being sarcastic? please say yes.
Old Mar 29, 2006 | 06:50 PM
oldsnail's Avatar
oldsnail
he must be kidding...
when you are about to be rear ended, please accelerate quickly
Old Mar 30, 2006 | 10:44 AM
robes's Avatar
robes
That's true. You should release the brakes for the exact reason stated.
Old Mar 30, 2006 | 11:55 AM
jeeper78's Avatar
jeeper78
That makes 0 sense from a whiplash standpoint. Releasing the brakes will allow your car to accelerate more quickly from the impact, leading to more severe whiplash. Your car may end up in better shape, but your neck won't. Now, if you're going to get hit hard enough that that your car may crush you, then, yes, release the brake. Energy from the impact will be used to move your car forward instead of crushing you and your car.
Old Mar 30, 2006 | 12:06 PM
freefallin's Avatar
freefallin
By "fully disengaged"...do you guys mean clutch pedal all the way to the floor? When I shift, I rarely push it completly to the floor.
Old Mar 30, 2006 | 12:30 PM
zedated's Avatar
zedated
jeeper, I like your explanation better.
As a follow-up... you can put your head against the headrest to protect your neck and reduce whiplash. Some cars now offer active head restraints that move the headrest closer to your head in a rear collision to reduce the movement of your head wrt your body, in order to prevent or reduce whiplash injury.
Old Mar 31, 2006 | 06:59 AM
Fletch69z's Avatar
Fletch69z
You don't want to stay on the clutch any longer than you have too. If it's a short period of time it's ok. Think of it this way. The more you use it the sooner the mechanics will break. Just let it out when you are sitting in neutral at a light and then reengage it.
Old Mar 31, 2006 | 09:31 AM
heezyo2o's Avatar
heezyo2o
There is nothing wrong with holding in the clutch at a red light, but it does increase wear on the pressure plate.
Old Mar 31, 2006 | 09:55 AM
MeetJoeAsian's Avatar
MeetJoeAsian
Originally Posted by oldsnail
correct me if i'm wrong...
I thought "riding clutch" meant driving with half clutch in + some gas wasn't it?
I don't see why clutch would wear down when it is fully disengaged
it doesn't hurt the clutch plate....it hurts the clutch assembly...the bearings and springs especially
Old Mar 31, 2006 | 10:06 AM
The Brickyard Rat's Avatar
The Brickyard Rat
"Riding the clutch" refers to having your foot on the clutch while the car is in gear & moving (and your not changing gears). This should be avoided as it will cause wear on the clutch. (Though I do it sometimes when stopped facing uphill).
Sitting at a light with clutch pushed in will only cause some excess wear on the springs that move clutch in/out. Probably best not to but not a big deal.
If a short light I leave mine pushed in. If longer light I put car in neutral & release clutch.
Old Mar 31, 2006 | 11:24 AM
elidoc's Avatar
elidoc
Well you cleared that up, Brickyard, now how can we improve on the knotchiness of shifting from 1st to second.....I'm up to almost 7000 miles after almost a year of driving the car
Old Mar 31, 2006 | 07:59 PM
  #38
DTLandLTD's Avatar
DTLandLTD
This is true.
However i believe that people are referring to two different things in this thread.
1.) It WILL NOT damage your clutch to have it fully depressed for any amount of time, since there is no pressure on it from the pressure plate, it simply freewheels with the engine, completely separate from any other components in the transmission.
2.) It WILL put unnecessary wear on the throwout bearing. when the clutch is engaged (pedal on the floor) the throwout bearing rides on the pressure plate spring. if it is held for extended periods of time, it puts a large load on the bearing, and can cause premature wear and failure.
Hope that helps clear things up a little bit.
Old Apr 1, 2006 | 11:07 AM
  #39
The Brickyard Rat
"...now how can we improve on the knotchiness of shifting from 1st to second....? "
Wish I knew on that one; 30,000 miles & I'm still not smooth all the time from 1st to 2nd.
Old Apr 1, 2006 | 11:36 PM
  #40
gsazabi's Avatar
gsazabi
Upgrade to JWT Clutch/Flywheel combo!
My JWT combo allows me easier shifting - I can shift much more smoothly.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
