Motordyne Install Help Needed
Old Mar 28, 2006 | 02:57 PM
NismoZ03's Avatar
NismoZ03
Default Motordyne Install Help Needed
I just completed the spacer install and now it is time to put the strut bar back on. With the spacers that are necessary I can't get the holes lined up correctly to mount it.
Which of the 3 nuts are you suppose to loosen?
Should I be pulling the wrench towards me or away from me to loosen it?
Old Mar 28, 2006 | 03:13 PM
Mike Wazowski's Avatar
Mike Wazowski
righty tighty
lefty loosy
Old Mar 28, 2006 | 03:27 PM
DevinB's Avatar
DevinB
haha a standard line mumbled to yourself when installing your own parts
Old Mar 28, 2006 | 03:35 PM
03performz's Avatar
03performz
Everything you need(info.) is in the directions.. It sounds like you didn't loosen the Strut bar adjustment nut before unbolting it. If you didn't do this the strut bar would prob. seem to short and wouldn't line up w/ the holes...loosen the adjustment nut the recommended turns in the directions..I think it was 1 1/2 or so.
drifter23's Avatar
drifter23
Yea the strut bar took me a while to get it to fit perfect. Just take your time.
Old Mar 28, 2006 | 04:00 PM
NismoZ03's Avatar
NismoZ03
So the adjustment nut is the one in the middle? Yeah the righty tighty helps but should the adjustment nut move to the driver side or passenger side when loosening?
Thanks for the help?
Old Mar 28, 2006 | 04:05 PM
Mike Wazowski
I believe left will bring it closer together and right will push it apart. If that makes sense.
Old Mar 28, 2006 | 04:22 PM
ROGUELITE's Avatar
ROGUELITE
the Zbler eLf
ha ha! i'm laughing because i just had my strut bar off the other day doing
my isothermal install. main thing like others said is to take your time. once
you get used to doing it a few times it will be pretty easy.
Old Mar 28, 2006 | 04:32 PM
Mike Wazowski
I just leave mine off now anyways LOL.
codek
Sep 27, 2015 03:21 PM
_koubie_
Sep 20, 2015 06:34 PM
