Question about when to shift when approaching redline
Old Dec 29, 2006 | 09:37 AM
350Zenophile's Avatar
350Zenophile
What's your point? Are you just trying to discredit the information?
Each line represents a range from 0? rpm to a redline of 6500 rpm for each given gear...thought that part was obvious. If you compare it to a dyno plot, you'll notice the shape of the curve looks hauntingly familiar.
Old Dec 29, 2006 | 10:58 AM
azula's Avatar
azula
Originally Posted by roast
rockinboy what you are describing is pretty close to being perfect. Although, #2 & #3 are pretty much a combined action, which instantly leads to #4. The only exception is that you might start to push the clutch a fraction of a second before you lift off the throttle, so you don't get any engine brake. It's best to push the clutch all the way(or as far as possible before engaging the next gear), and as fast as possible. You drop the clutch the instant you have engaged the next gear, before the rpm have had a chance to drop for an upshift revmatch. The extra power is sent to the wheels and the clutch is given a chance to grab. This is known as speedshifting, and it's the fastest way down the strip. It is only slightly stressful on your drivetrain, and nowhere near as bad as powershifting, but best of all it's faster.
so speed shifting is basically regular shifting on crack? there's nothing really different that's going on that I can see, correct me if i'm wrong please...
Old Dec 29, 2006 | 11:11 AM
bailey bill's Avatar
bailey bill
The information is just fine, it just doesn't have anything to so with the discussion. It shows a relationship between torque and speed, not power and RPM.
Your confusing torque and power.
Your graph shows a relationship between speed, and torque, and how it is changes from one gear to another. It tells neither of us anything about a relationship between RPM, and power.
Power is the product of RPM and torque (HP = RPM X torque/5252) lower gears increase torque, and reduce output shaft RPM, and higher gears reduce torque and increase output shaft RPM. But since one variable inceases in direct proportion to the decrease of the other variable, the product is always the same.
The torque will be higher or lower, depending on what gear you choose. But HP will be the same. And regardless of the actual peak value, it will always occur at the same engine RPM.
bill
Old Dec 29, 2006 | 12:28 PM
350Zenophile
Ahhh, I wasn't confused about anything but the point you were trying to make. I was using general language as most people do not distinguish between power and torque. If you want a graph that shows power in relation to RPM that is called a dyno plot. Do a search, there are tons on here.
This doesn't change my point that shifting at redline will accelerate the car faster than short shifting, which is what I thought the OP wanted to know 8 months ago when I originally made the post you are refuting.
If he wanted to know the physics behind it I would have pointed him here:
http://craig.backfire.ca/pages/autos/horsepower
Old Dec 29, 2006 | 12:49 PM
Kolia's Avatar
Kolia
The point being, even if the engine power will drop after 6,400rpm, holding the lower gear as long as possible and shifting just before the engine hits the rev limiter will generate the maximum acceleration.
Old Dec 29, 2006 | 02:35 PM
bill
Thats some impressive technical stuff. Post a time slip here and lets see how it works: https://my350z.com/forum/drag/233840-top-25-1-4-mile-times-for-tt-st-supercharger-nitrous-bolt-ons-stock.html
Old Dec 29, 2006 | 02:42 PM
Question
Wrong. Actual peak wheel power takes into consideration gear multiplication. I say actual b/c dynos are programmed to remove gear multiplication from the equation providing a standardized 1:1 ratio for comparison purposes. 5th gear in a 6spd is typically closest to being direct drive while each successively lower gear provides an increase in actual power to the wheels. Taking this into consideration, redline in 1st or 2nd gear will put more power to the pavement than the next gear shift up unless you have an abnormally sharp drop in power after peak. See attachment.
How does that work out racing a real car in the real word. Post a time slip here: https://my350z.com/forum/showthread.php?t=23384
Old Dec 29, 2006 | 03:19 PM
Fingers's Avatar
Fingers
I think what he is trying to show you guys is that at 38-42mph in first gear you will have more power then shifting early and being at 38+mph in second gear. He is talking about usable power within each gear or taking every gear to its maximum mph. The car also has momentum and is still accelerating during the short period of time when the clutch goes in and out again, which is also another good reason to take every gear to right before redline because every increase in your mph will = being deeper in the power band for the next gear, thus having more power and acceleration. Hopefuly some of this made sense or someone else can come along and explain it better.
Old Dec 29, 2006 | 03:27 PM
Fingers's Avatar
Fingers
Lol just wanted to let you know, before you hit me on that, mine will be in there as soon as I get a chance to go to track.
Old Dec 29, 2006 | 03:30 PM
Reality350's Avatar
Reality350
^LoL!
Old Dec 29, 2006 | 03:36 PM
bailey bill
A "dyno plot" overlays 2 curves, or graphs. One shows torque in relationship to RPM, and the other shows (horse)power in relationship to RPM.
They are 2 different variables,have different curves, and peak at 2 different points.
bill
Old Dec 29, 2006 | 04:03 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Thats some impressive technical stuff. Post a time slip here and lets see how it works: https://my350z.com/forum/showthread.php?t=233840
davidv's posts like that are always funny
Old Dec 29, 2006 | 05:08 PM
derekinthez's Avatar
derekinthez
Default Sense?
Yeah, this is common sense I would think and put this way eliminates the need for people to articulate what they learned in Mechanical Engineering 101.
Old Dec 29, 2006 | 05:11 PM
350Zenophile
bill
My interest in this thread peaked 8 months ago.
Since you are so good at posting definitions, which plot shows the relationship between my disinterest and your ability to state the obvious?
Old Dec 29, 2006 | 05:55 PM
Kolia's Avatar
Kolia
Just to shime in that, as soon as the clutch goes in, the car will instantaniously decelerate, in proportion to mechanical and aerodynamic drag. It stops "gaining" mph the moment power stops being transmitted to the ground.
Let's not let the human internal ear perception of acceleration or the speedometer needle going forward non stop as we up shift induce us in forgetting the laws of physics. Our perception is wrong, the speedometer needle is dragging behind the car's actual speed from it's own inertia (it barely catches up when we get back on power).
Old Dec 29, 2006 | 06:30 PM
alann's Avatar
alann
Old Dec 29, 2006 | 08:17 PM
LOL. I race on weekends, and don't know all this technical stuff. In fact when I think too much, I screw up and those are my worst races. Looking forward to your time slips.
Old Dec 29, 2006 | 08:25 PM
  #38
Thumbs up
BTW I have seen your times. Nice driving.
Old Dec 29, 2006 | 09:51 PM
  #39
3hree5ive0ero
Retired Admin
Well, thank you. That means a lot to a noob drag racer coming from a veteran. I've only been to the strip 5-6 times, but I think I'm gettin the hang of it.
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
