what the hell
Old Apr 5, 2006 | 10:19 PM
new_one's Avatar
new_one
Default what the hell
my car is idiling at 1000 rpm is that normal. Just wonderin, thank you in advance
Old Apr 5, 2006 | 10:22 PM
kcobean's Avatar
kcobean
Is the car new to you? If so, it's possible that the previous owner had the idle raised by the dealer to prevent rough idle. If not, is the car at operating temperature, or does it only do this when you first start the car. Did it just start doing this or has it always done it. How long has it been doing this? What changed since it started doing this.....
questions, questions....
Old Apr 5, 2006 | 10:49 PM
Cannysage's Avatar
Cannysage
maybe the throttle body's all greased up and closed.. but that usually don't happen on newer cars.. you may have a vaccum leak, but that usually get your idle to 1500ish. .7k is normal.
Old Apr 5, 2006 | 10:50 PM
Casanova's Avatar
Casanova
lol, Where did you come from? Who is your father?
Old Apr 5, 2006 | 11:00 PM
kcobean's Avatar
kcobean
.....It's the curse of being an IT professional.....I immediately go into troubleshooting mode when given a problem and NO detail.
Old Apr 6, 2006 | 08:55 AM
fairladyinit's Avatar
fairladyinit
It doesn't sound like a problem. Even an intake will lower your idle. Kelly's probably right, if you purchased your Z with mods then it's likely that person raised his Idle.
Old Apr 6, 2006 | 09:11 AM
Silkk's Avatar
Silkk
I think 500-1000 idle could be normal on an 03-06 Z depending on various factors. Usually it is somewhere in the middle, but I don't think 1000 would hurt a thing...
Old Apr 6, 2006 | 09:28 AM
kcobean's Avatar
kcobean
Yeah, it's definitely not "bad" for the car unless it is a sign of a vacuum leak as Cannysage suggested (i.e. engine is getting air that is not being metered via the MAF/throttle-body). If that were the case, I'd want to fix it. If not, it's fine, but it's not the stock idle setting for the car at operating temperature.
Old Apr 6, 2006 | 10:46 PM
new_one's Avatar
new_one
soeey its an 06
HoBrahYouStink
Jun 24, 2016 10:58 PM
stratxc
Sep 21, 2015 08:47 PM
crashandburn420
Oct 10, 2002 06:36 AM
