Work Meister 3piece offset questions
Old Apr 7, 2006 | 07:17 PM
sal501's Avatar
sal501
Default Work Meister 3piece offset questions
Hopupracing is selling the following wheels/offsets. Would 18 x 10 with 18 offset rub, if the car is not lowered. I don't want to lower my car. What are the thoughts on 18 x 8.5 and 18 x 10? Would they be flush? or tucked in?
Offsets:
18 x 8.5 5 114.3 24
18 x 9.5 5 114.3 29
18 x 10.0 5 114.3 18
Old Apr 7, 2006 | 08:50 PM
Use one of the offset calculators above and compare the new wheels to your current ones. Then check the car with a tape to see if you will have any clearance problems.
Old Apr 8, 2006 | 01:41 AM
PL510_Z33's Avatar
PL510_Z33
So in the front, 9.5+29 could be a little close to the important mechanical bits that absorb the asphalt acne, so that may need a spacer, but the back sound OK. Lots run 10.5+22 in the rear, so your possible 10.0 +18 needs 1/2" LESS room on EITHER side given the same offset, but then is 4mm shifted negative (towards the outside)...lets see, 1/2" = 12.7mm, but we subtract 4mm to arrive at 8.7mm MORE room than a 10.5+22 ... Did I get it right? I really shouldn't do math @ 2:30am!!!
In other words, you shouldn't rub, lowered or not.
j!
Old Apr 8, 2006 | 06:58 AM
jinsei888's Avatar
jinsei888
go negative offsets, thats the only way to roll hard haha "-4" for life!!!!
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
Shane86
Sep 17, 2015 05:33 PM
etong
Sep 10, 2015 06:14 PM
lolsupfoo
Sep 9, 2015 12:57 PM
