Ride dif. between 03-04 & 05-06 Z
I know Nissan softened the suspension a little in the 04.5 or 05 Z's, I was wondering if there's a major ride difference between those and the 03 and early 04's? Also what did they actually change in the suspension to do this? Is it just softer springs or is there more to it than that?
I test drove an 03,05,and an 06. The 06 I test drove, the transmission and gears did not seem smooth (im sure because it was new, less than 100miles). What I did feel in the 06 is not as much power down low than the other two years I drove. The 05 I was going to buy but the dealer did not want to make a deal, I drove this car for about 30minutes. I really felt no difference in the suspension between the years, but maybe that is just me. I think the 06 came with a different suspension, possibly to put to rest the tire-feathering problem. FYI I bought the 03 and have not looked back...not yet atleast.
Originally Posted by Ed 718
try riding in a shopping cart sometime and when you do say to yourself " so this is how the 03 Z feels like "
Originally Posted by NissanZfan
I don’t know man, the ride doesn’t really bother me that much. My dad has a 90 300zx with a suspension setup and if you think your Z is bad, Ill set you up for a ride in his. I have hit my head on the top of the car a few times while going over a bump. I have also drove in some chicks Honda, and man that thing was REAL bad. Over all I don’t feel a noticeable difference in the ride through out the different years.
I just can't stand the bouncy feeling of the 03 as compared to the revised suspension. Now the car I had before the Z was the 02 nissan Altima fully loaded which was uber smooth on the freeways. The 03 however if you rest your head on the seat for a ride you'll be boucing everywhere.
Thanks for the replies. I have an early 04, and it's a bit harsh on bad roads, I figured the difference wasn't that major but I thought I'd ask. I figured If there was a major difference and it was just softer springs it might be worth looking into. But i'd hate to lose too much handling anyway.
Check out the spring database
https://my350z.com/forum/brakes-and-suspension/154233-spring-rate-database.html
Oem springs 350Z’s 2003/2004
Front:314 Rear:342
Oem springs 350Z 2004.5/2005 (found 04 car's that have the revised susp.)
Front:314 Rear:427
The big complaint in the early cars was porpoising on the freeway.
Chris
Front:314 Rear:342
Front:314 Rear:427
Chris
My 03 Z got more bouncy as I hit a few bumps(lots of train tracks and messed up roads in San Francisco), now my car feels like a boat floating around sometimes, especailyl in low speed, at high speed, it is still acceptable, but still it is bouncier than be4. Was it just me or does anyone have similar problem? Or the 03 stock suspensions get worn out just like that over time? Could somebody shed a light on me ?
Front:314 Rear:342
Front:314 Rear:427
How do you add 85lbs spring rate and "soften" the suspension? How do you increase rear spring rate 25% on a good handling car and not oversteer big time?
Front:314 Rear:342
Front:314 Rear:427
The 03 setup is the original US spec and it was softer, presumably because the US market likes it soft.
Stiffening the rear will reduce understeer.
Chris
the 03 stock suspension is really unacceptable in terms of doing aggressive driving! IT gives u a very unsafe feedback. As for going at high speed, you can still feel the little bouncing up and down, and I really dont appreciate that kind of communication with the car.
Originally Posted by HyperSprite
The 04.5 setup is the stiffer Euro spec.
Chris
Chris
Originally Posted by heezyo2o
I remember reading posts of how some thought the '03s handled better due to more negative camber and a few other things. Is this true?
. I personally love it though.
