recomendation to those with 1000miles or more
Old Feb 4, 2003 | 11:12 AM
ares's Avatar
ares
Veteran
Default recomendation to those with 1000miles or more
go on outside, pop the hood.
undo the 2 little clips on the filter, just pull em up, then pull the filter toward you and up. out comes the filter. now have fun. I just did it, there was like 7 leaves in there. that cant be good for performance. since were all trying to get like .5CI of more air in there, this is something we should all be sure to check.
I only have 3000 miles btw. but theres leaves in there.
Old Feb 4, 2003 | 12:47 PM
justwant1's Avatar
justwant1
Thanks,
I will have to check that out.
Old Feb 4, 2003 | 01:51 PM
Red350Z's Avatar
Red350Z
.....Good call ares, I not only had leaves, but 3 pieces of paper, one of them almost the size of an index card! Thanks!
Old Feb 4, 2003 | 02:53 PM
gstdtim's Avatar
gstdtim
This may be a terrible question, but can you describe to me exactly where the filter is?
Thanks
Old Feb 4, 2003 | 03:10 PM
ares's Avatar
ares
Veteran
facing the open engine bay, its going to be on your right. the filter itself is the large black box thing with a yellow sticker on it I believe.
there will be 2 metal clips on top that pull up. to unlock it so you can pull it foward away from the lip, and then up and out.
the intake box is at the very bottom of this pic, you can even see the clips, they look silverish white in the picture, there round peices of metal.
Old Feb 4, 2003 | 05:21 PM
flyz33's Avatar
flyz33
ahh yeah, thanks man; I'm gonna check it out
Old Feb 4, 2003 | 05:28 PM
JonsilvZ's Avatar
JonsilvZ
Actually I looked in the opening out of curiousity and found a couple of leaves. I put my fingers in there to take them out. Theres got to be more crap in there.
Old Feb 4, 2003 | 06:58 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
When I changed over to the K & N filter I dug out 3 leaves as well. It's amazing what gets sucked up in there!
Old Feb 4, 2003 | 08:49 PM
N74DV's Avatar
N74DV
hell... when I popped mine after 2,000 miles I found 2 leaves, a McDonalds large cup lid and straw and get this..... a shoelace.
Old Feb 4, 2003 | 09:00 PM
s9am_me's Avatar
s9am_me
well.. checked it out.. and guess what was in there... a freagin bird!!! nah j/k.. only one small leaf in the box but i found some small dead bugs on the filter tho
Old Feb 5, 2003 | 04:30 AM
Phi-1002-'s Avatar
Phi-1002-
You guys shouldn't be driving through the forest
Old Feb 5, 2003 | 05:37 AM
noahbuddy's Avatar
noahbuddy
When I switched to the K&N Filter, I had a ton of crap also. took the shop vac to it and cleaned it out. Most of the debris was to small to get out by hand.
Old Feb 5, 2003 | 07:50 AM
rahilio's Avatar
rahilio
i found some ****!!!!!!!!!!!!!!!
Old Feb 5, 2003 | 08:00 AM
mcduck's Avatar
mcduck
ares... good advice... I discovered the same thing the hard way.
Went to dyno my Z. After two disappointing base runs, we pulled the filter to simulate the improvement a higher flow filter would get me.
Upon removing the filter, we found several leaves, two candy bar wrappers, an astonishingly large piece of newspaper, and a small plastic bag!!!
Needless to say, my third run was better than my first two. I gained almost 10 hp and 10 ftlbs of torque just by removing the crap from my intake!
Old Feb 5, 2003 | 11:12 AM
ares's Avatar
ares
Veteran
did you check yours? I only waited 3000 miles cause I didnt think anything would have gotten in there. I drive on clean roads all the time. or so I thought.
Old Feb 5, 2003 | 11:56 AM
Turcoupe's Avatar
Turcoupe
Just checked mine....2 small leaves (450 miles so far).
Thanks for the heads up!
Old Feb 5, 2003 | 12:04 PM
LA-Z's Avatar
LA-Z
Wow...9000 miles and I haven't checked it once. Can't wait to find the good stuff.
Old Feb 5, 2003 | 03:15 PM
Z CRAZY's Avatar
Z CRAZY
Charter Member #67
I found the neighbor's dog that ran away last month in there! I'm sure they will be grateful.
Steve
Old Feb 5, 2003 | 04:26 PM
Brad4rdHay's Avatar
Brad4rdHay
I had a TON of **** in there when i checked it out. A def, every 500 mile check, as it takes two seconds to do.
Old Feb 5, 2003 | 06:17 PM
Electro Z's Avatar
Electro Z
Default Thanks!
Three leaves and the lady next doors small dog.
removed all items from filter. Dog pissed.
Will have to check it every 1000 miles.
EZ
