All This Talk About Clutches.....
Old May 6, 2006 | 12:56 PM
Kabs's Avatar
Kabs
Default All This Talk About Clutches.....
Im just wondering...how do you know your clutch is slipping or your clutch/flywheel needs to be replaced?
I have driven manual tranny cars for a while and never had a clutch or anything involved with the transmission break on me. My Z is running strong, no problems with the tranny (sometimes hard to get into gear when its cold but thats normal)
A while ago I felt like a rebel and decided to try to "peel out" and I def burned my clutch since there was a really bad smell. After that I promised myself never again.
Im wondering out of curiosity... how do you know your clutch is in need to be replaced? Will your car jerk while you are driving normally? Will your RPM's be screwed up?
Thanks
Old May 6, 2006 | 01:00 PM
imseksy's Avatar
imseksy
when the clutch slips you will notice that the gear doesnt "engage" fully. when you are in gear and you let go of the clutch, the engine will rev for a little bit and then "bite". thats when you know you need a new clutch.
Old May 6, 2006 | 01:48 PM
When you engage the clutch, the car does not move.
The clutch is always engaged. Which isn't too bad because you can start the car in first gear. Just make sure nothing is in front of you.
Old May 6, 2006 | 02:19 PM
Kabs's Avatar
Kabs
hmmm thanks guys =)
how many times can you burn the clutch without having to worry.... i mean i only did it once and almost got a heart attack...... i know there is no real number (ex. 6 times) but how does it affect the life of the clutch?
Old May 6, 2006 | 02:22 PM
gsazabi's Avatar
gsazabi
When I'm coming to a stop and depress the clutch to
put it into neutral, the rev goes up like 500rpm for a second before dropping to proper idle.
Is that normal? Just curious.
Old May 6, 2006 | 04:06 PM
Ken Corsun's Avatar
Ken Corsun
Thanks
Put the car up against a solid object (with some sort of padding if you want). Engage a high gear (5th or 6th) and slowly let out the clutch pedal. If the car stalls you're ok, if the car doesn't stall and the clutch pedal comes all the way out, your clutch is worn.
Ken
Old May 6, 2006 | 04:17 PM
Kabs's Avatar
Kabs
interesting... ill have to try that one day.... cant i do this on a flat surface without pushing on something?
Embarassing as it is... i did stall out this past week.... dont remember why (hasnt happpened since god knows when) but i guess it was good sign no?
Old May 6, 2006 | 04:41 PM
roast's Avatar
roast
I would recommend against trying something like this. If you can't tell your clutch is worn from driving it..... if it ain't broke, don't fix it.
Old May 6, 2006 | 07:12 PM
Jyoder7's Avatar
Jyoder7
I've heard some people say that if you don't stall every now and again you're using too much clutch.
Old May 6, 2006 | 07:40 PM
Wangatang's Avatar
Wangatang
yes. the flywheel momentum keeps the crank spinning for that brief period
Old May 6, 2006 | 11:06 PM
roast's Avatar
roast
lol... now we're just getting silly....
Workshop12
Mar 23, 2020 01:45 PM
May 12, 2016 07:42 PM
Sailors350Z
Sep 25, 2015 08:21 AM
