"Black box" in Z?
Old May 25, 2006 | 04:03 PM
Z_freak's Avatar
Z_freak
I did some investigating on this and unfortunately it is all integrated with the ecu, sorry peeps, no disableing....on the good side of it, if you were in an accident and someone tried to say you were speeding and you were not then you could hang thier lyin ***....
Old May 25, 2006 | 05:30 PM
DavesZ#3's Avatar
DavesZ#3
Originally Posted by 03performz
Whoever gets a good DIY up on disabling this thing should get to be God for the rest of their time here.
I doubt you could disable it as it is probably built into the "brain" of the car - the ECU.
Old May 25, 2006 | 05:39 PM
fowlman01's Avatar
fowlman01
Will they know if I ********** in myZ?
Old May 25, 2006 | 05:45 PM
Max_PSi's Avatar
Max_PSi
Like the paragraph said, it doesn't record sounds. I guess your in luck.
Old May 25, 2006 | 05:52 PM
s2kphil's Avatar
s2kphil
it also doesnt say anything about having a magnafying lens, so again you are ok..
j/k
Old May 25, 2006 | 06:08 PM
NightRida's Avatar
NightRida
The PC can be hacked into fellas with the proper equiptment! Any programmers on here that deal with vehicle data coding?
Peace!
Old May 25, 2006 | 07:19 PM
Johnny225's Avatar
Johnny225
There must be someone out there who can recode the ecu to take out the code for this. this is f****ing BS.
EDIT: Will resetting the ECU really get rid of this data? Isn't it possible that the data is cached somewhere so that resetting it won't wipe the data?
Old May 26, 2006 | 05:39 AM
DavesZ#3's Avatar
DavesZ#3
I doubt someone will recode the ECU - after all, it's taken years just to get reflashes available just to change the fuel maps. That's nothing compared to changing the operation of the ECU.
I doubt that resetting the ECU would wipe the data clean. Say the car gets in an accident and the battery is destroyed/disconnected. Normally, the ECU "resets" by disconnecting the battery for 24 hrs. If it cleared the crash data, if you didn't pull the ECU immediately and read the data, you'd have no way to get to it. It has to retain the data no matter what happens, much like an airplane flight data recorder.
Old May 26, 2006 | 05:57 AM
fowlman01's Avatar
fowlman01
As DavesZ#3 says I think it would retain the info, but it seems as if anything can be hacked. If Nissan can retrieve it some one can probably delete it.
Old May 26, 2006 | 06:51 AM
DavesZ#3's Avatar
DavesZ#3
I'd bet it can be accessed and deleted with the Consult II module that Nissan uses.
Old Jun 9, 2006 | 12:56 PM
New2350's Avatar
New2350
You gonna try and delete it with 6 cops, 2 fire trucks, one ambulance, and a couple of news helicopters watching after the wreck? Might as well light it on fire. Or run away.
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
Tochigi_236
Sep 27, 2015 03:40 PM
