Driving around in 3rd?
Old May 29, 2006 | 06:12 PM
Miko's Avatar
Miko
Default Driving around in 3rd?
When I drive ~40-45 in 3rd, at about 3500-4000 RPM is it the VQ or the exhaust that's really loud, or both of them? I enjoy cruising around sometimes in 3rd at these RPMs and hearing the rumble...besides guzzling gas at this speed, is it bad for the engine or trans at these RPMs in terms of overheating any engine/trans components?
Old May 29, 2006 | 06:25 PM
Jyoder7's Avatar
Jyoder7
The sound your hearing is coming from your gas money going down the drain.
Old May 29, 2006 | 06:29 PM
priscilla ls1's Avatar
priscilla ls1
I hear that it is bad on you MPG.
But good for the engine on some cars to have it in a higher rpm while crusing
Old May 29, 2006 | 06:30 PM
Miko's Avatar
Miko
I don't do it constantly, but I drive this car to enjoy every minute while driving it...otherwise I'dve bought like a civic and scion lol
Old May 29, 2006 | 06:31 PM
Swiffer's Avatar
Swiffer
You should not be running it at those RPMs for an extended period of time. Waste of gas, and unneccessary wear on the engine/trans.
Old May 29, 2006 | 07:00 PM
tienlo's Avatar
tienlo
Yeah it creates more heat (more fuel burnt and friction per mile) and less air goes through the radiator so less cooling (relative to engine speed)
More friction on moving parts eg gearbox
but for short periods of time its fine.
Old May 29, 2006 | 07:03 PM
rightwinger's Avatar
rightwinger
Ya, actually I have a question to. Idk if its the tire/road noise, but I drive around 35-50MPH in 5th-6th gear to reduce the noice..And ive heard I will get better MPG at higher gears.
Old May 29, 2006 | 09:03 PM
Miko's Avatar
Miko
Accelerate slowly, and shift @ 2000 RPMs, and cruise in 6th at 45-50 and you'll get like 28+MPG...it really makes that much of a difference. I drove 60+ miles and I was getting 29 MPG, in the city at night with not much traffic. I asked others if the guage is accurate, and many say its pretty close, off for some by 0.5 to 2.0 MPG
Btw, when I popped the hood, I saw this little thing on the left side, (I think behind the radiator) and it looked like a small oil cooler. Is this for the trans oil or the motor oil? Why do manual trans's have much less fluid than A/T?
Old May 29, 2006 | 09:11 PM
SHO-TIME's Avatar
SHO-TIME
i'm getting 18 mpg (city/hwy). it's all good.
Old May 29, 2006 | 09:17 PM
fowlman01's Avatar
fowlman01
With my borla's it sounds good at 2000 rpm, but I'm at 3k at most highway driving. 18 city and 27 +/- highway. 10 mpg at the drags.
Old May 30, 2006 | 11:10 AM
dLyte00's Avatar
dLyte00
i'm a noob also....So when cruising i just keep shifting up @2K until i get to 6th gear and just cruise at 45-50 mph?
Old May 30, 2006 | 11:30 AM
Silkk's Avatar
Silkk
You shouldn't really be driving a Z... no let me rephrase... a manual transmission if you have to ask questions like this?!
Old May 30, 2006 | 11:40 AM
Manu's Avatar
Manu
Why should it be worse to drive around at 4000rpm in 3rd rather than 6th
Old May 30, 2006 | 11:49 AM
Silkk's Avatar
Silkk
Why is everyone so damned concerned with shift points?!? Shift between Idle (800RPM) and redline (6600RPM) and you should generally be "O.K."
Obviously shifting at different RPMs will cause different sounds, different gas mileage rates, different wear and tear, etc. but come on people... it's like a bunch of teenagers discussing how to drive stick before they ever get into a car... Do y'all actually REALLY own Zs?!?
Old May 30, 2006 | 11:50 AM
Kolia's Avatar
Kolia
It's not.
I seriously doubt you’d see much difference in coolant temperature. If you did, you’d notice it on your dash.
Run in any gear you like. You will be wearing your engine faster since it doing more rpm. But your Z will still rust out before the engine dies from that. The rest of the drive train won’t see any difference at all since all gears are always meshed and always spinning in the gear box. As for the final drive, it’s spinning at wheel rpm regardless of selected gear.
AT Tranny use oil to transmit torque instead of a clutch. Have a look at HowStuffWork.com for details.
Old May 30, 2006 | 11:52 AM
NeoRacer_106's Avatar
NeoRacer_106
why do you wanna be like those ricers in a lowered civic driving around in 1st gear to get the most obnoxious noise possible?! I heard it impresses the girls
Old May 30, 2006 | 12:07 PM
roast's Avatar
roast
I second what kolia has stated. Good post.
although the site is howstuffworks.com
Old May 30, 2006 | 12:11 PM
rythex's Avatar
rythex
So if I drive around in 1st and redline it all the time that's coo?
Old May 30, 2006 | 12:18 PM
Silkk's Avatar
Silkk
I always cruise at about 6000RPM in 1st when I'm in small towns with 25-35MPH speed limits...
I heard it is great for it!
Old May 30, 2006 | 12:21 PM
Adibese's Avatar
Adibese
Why do people insist on buying a 350 to "cruise" and get great mpg? There are better cars for that.
