Is my tire pressure monitor accurate?
on
I believe the general consensus is that the TPS is pretty accurate. However, I just got a longacre, liquid-filled tire gauge and it doesn't agree with the TPS. Checking with the gauge, I got 34-35 psi cold, but when I drove the car right after, the TPS reads 31psi.
The TPS has been reading around 34psi cold and has since been losing pressure over time. I thought this was normal, so I was going to add some air, but my gauge suggests otherwise.
I previously used a pencil type gauge along with an accutire gauge. I lost those two, but I remember them matching up with the TPS. Although the accutire would disagree at times. I always had a hard time getting consistent readings with the accutire, but that's beside the point.
Administrator
+/- 2psi
on
I think it's common for tires to lose a little air over time, but does this mean that my TPS is inaccurate or that the longacre tire gauge that adjusts for temperature is inaccurate?
Here's the gauge that I just got http://www.longacreracing.com/catalo...d=1118&catid=8 It's a pretty decent piece from a reputable company so I'd like to trust it's accuracy.
