Low Oil Pressure
Old Jun 3, 2006 | 04:10 PM
pitbull21's Avatar
pitbull21
Default Low Oil Pressure
I have an 06' 350 Z with 500 mi. My oil pressure at idle is about 15 psi. Car is idling at about 700rpm. When the AC is on it idles a bit higher and the pressure is closer to 30 psi. Does this seem like a problem to anyone? I am very concerned. Oil level is fine. I was thinking of changing the oil and putting in a heavier weight but it does't seem like I should have to do that on a brand new car. I have to admit that I have taken it over 4000 rpm a couple of times, could I have ruined this motor already?
Old Jun 3, 2006 | 04:19 PM
duckypower's Avatar
duckypower
its ok i just got my 2006 grand touring roadster 2 weeks ago and i thought there was something wrong with my oil pressure since its only 15 psi at idle and when you start giving it gas it goes up, i checked all 350z are like that
so no problem just have fun!
Old Jun 3, 2006 | 04:20 PM
pitbull21's Avatar
pitbull21
Thanks I feel much better.
Old Jun 3, 2006 | 04:23 PM
diwun67's Avatar
diwun67
Don't think so much!! Of course your oil pressure is going to go up with engine speed, the oil pump is crank driven And if you switch to a heavier oil your pressure will go up throughout the rpm range. And don't worry about having taken it over 4K rpms, you're already past your initial break-in, just try not to do it again til ~1,000 miles. You'll be fine.
Old Jun 3, 2006 | 04:25 PM
TheCajunStyle's Avatar
TheCajunStyle
From the factory service manual:
At idle: >14psi
2000rpms: >43psi
Looks like you're OK.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
