Window Grease and Warranty Question?
Old Jun 7, 2006 | 10:28 AM
cubbiekidd22's Avatar
cubbiekidd22
Default Window Grease and Warranty Question?
I have the good old window grease marks, and the dealership says that is not covered by my warranty? Is that correct or should it be covered? any help would be nice. Thanks.
Old Jun 7, 2006 | 10:33 AM
Is there grease on the windows of other cars? If the answer is no, then it is a deficiency in materials or workmanship. Deficiencies in materials or workmanship are covered by warranty.
Old Jun 7, 2006 | 10:36 AM
Ztalker's Avatar
Ztalker
isn't there a TSB for the window grease marks?....i had both window grease marks taken care of under warranty from day one back in 03....my driver side still has a tiny grease mark, but it don't bother me no more.
Old Jun 7, 2006 | 10:54 AM
cubbiekidd22
From what I have read, its better to just deal with it than have them try to fix it. Seems like more problems come out of having them fix it.
Old Jun 7, 2006 | 11:21 AM
Ztalker's Avatar
Ztalker
your absolutely right my friend....chances are one problem would lead to another. i remember i had to bring the Z back at another time for them to replace the passenger window (someone scratched it by accident)
Make sure to check your vehicle carefully before driving it home from the shop.
Old Jun 7, 2006 | 11:28 AM
Lega-Z's Avatar
Lega-Z
Im a detailer at a nissan dealership, and i run across this problem alot, even with my own Z... i've even see this on the 06 roadsters... cubbie is right... if they try to fix it... theres a good chance ur going ot get friction noise from your window when u let it all the way down... just keep a can of foaming streakless glass cleaner on ur glove box... it wont kill you to whipe your windows once in a while... i do it for customers all day....
Old Jun 7, 2006 | 12:07 PM
cubbiekidd22
Thanks guys.
Old Jul 5, 2006 | 03:54 PM
UltraYellow350z's Avatar
UltraYellow350z
Just put my '05's windows for the first time and driver's windows has grease. I read about the fix thing and I agree that unless its dire, I shouldn't get it fixed.
Just out of curiousity, what do they replace to fix the grease? Is it just cleaning up the grease or is there a mechanical fix?
Thanks!!
Old Jul 5, 2006 | 04:49 PM
black_03's Avatar
black_03
If you do a search their is a thread that has been created to fix this yourself I followed it and no more grease. Basically you take off the door panel and look down your window and their is type of band with soft bristles on it and you are able to pull it out with needle nose pliers, it worked.
issyz
Jul 2, 2017 03:04 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
