How do I burn out in one spot??
Old Jun 13, 2006 | 07:53 PM
oman's Avatar
oman
Default How do I burn out in one spot??
I wanna do a burn out in one spot. How do I do that? how do I lock in my front wheels?
Old Jun 13, 2006 | 07:57 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
You've gotta pull the brake fuse, when you hit the gas and brake at the same time the Z cuts engine power. The fuse will disable this and your brake lights so be sure not to drive without it.
Old Jun 13, 2006 | 08:00 PM
Nitrouz's Avatar
Nitrouz
Back to Z
pulling the fuse is a good idea, but you don't have to. When the brake lights come on, it cuts 35% of the power, but you'll still burn fine. This is of course on a 6mt. On an auto, you will have to pull the brake fuse if I'm not mistaken.
btw...it's called a standing burnout. I did a search for you but only came out with 1 informative thread.
https://my350z.com/forum/showthread....anding+burnout
Old Jun 13, 2006 | 08:04 PM
Santacruzslick
Veteran
I dunno, my 04 auto did hella sweet standing burns. Hit the brake and mash the gas and they just light up like crazy! Haven't been able to do a standing burn on my 06 6MT, I just stall or overcome the brakes and move forward very slowly.
Old Jun 13, 2006 | 08:11 PM
oman's Avatar
oman
Guys I dont drive an auto 2 reasons not a girl and dont know how to drive an auto? I have a six speed.
Old Jun 13, 2006 | 08:12 PM
Nitrouz's Avatar
Nitrouz
Back to Z
try letting it burn FIRST...even if it rolls forward a bit. Then tap on enough brake to stay in one spot (not mash the brake), and it should be fine... Works for me anyways...
If you wanna see a really nice standing burnout, click on fowlman's sig where the links says "the burn".
Old Jun 13, 2006 | 08:23 PM
InSaNeZ's Avatar
InSaNeZ
^ +1
I also usually let it roll a bit, I think it's easier that way.
Old Jun 13, 2006 | 08:28 PM
Santacruzslick
Veteran
Well...I'd go play with it a bit but my tires are totally bald, it's pouring rain, and I haven't ordered new tires yet...
Old Jun 13, 2006 | 08:30 PM
Zerk's Avatar
Zerk
I think the guy was trying to help you out and you are calling him and every other person that drives an auto a girl?
Is this a tread about doing a standing burnout or are you just trying to be disrespectful?
Old Jun 13, 2006 | 08:33 PM
Nitrouz's Avatar
Nitrouz
Back to Z
only make things easier.
Old Jun 13, 2006 | 08:44 PM
A line lock would be helpful.
Old Jun 13, 2006 | 08:45 PM
Santacruzslick
Veteran
Haha, easier...or much more expensive. lol
I was on the way home tonight, 4th gear going about 40sh, hit the gas to accelerate when the limit went from 35-45 and I freakin lost traction...I was like wholy ****...did that just happen!?
Old Jun 13, 2006 | 08:46 PM
kcobean's Avatar
kcobean
David,
I heard 'line lock' mentioned in another thread. Being a drag-racing novice, can you enlighten me on what this does? It seems pertinent to the topic at hand.
Old Jun 13, 2006 | 08:54 PM
Originally Posted by kcobean
David,
The line lock allows you to lock only the front brakes. If you are on racing slicks, a complete burn-out is necessary to make the tires sticky.
Old Jun 13, 2006 | 08:58 PM
New2350's Avatar
New2350
david will ask you to search for it.
Old Jun 13, 2006 | 09:00 PM
kcobean's Avatar
kcobean
Thanks!
Old Jun 13, 2006 | 09:13 PM
k4nx's Avatar
k4nx
whats the point of burning out in 1 spot,
then again,
whats the point of burning out unless ur warming up tires
Old Jun 13, 2006 | 09:17 PM
Santacruzslick
Veteran
then again,
to be cool...
Old Jun 13, 2006 | 09:25 PM
Miko's Avatar
Miko
In fowlman01's "the burn" vid (http://rabbit.circa.ufl.edu/albums/a...altburnout.mpg) and other burnouts that I've seen, I hear this noise that sounds like it's hitting off the rev limiter, is it something else? You can hear it in this vid at 11 seconds when the car starts to move forward.
Old Jun 13, 2006 | 09:36 PM
Nitrouz's Avatar
Nitrouz
Back to Z
it is hitting the limiter. You have to keep your foot on the gas and hit the limiter until you let go of the brake, or it'll catch traction and you'll either dart out (not enough brake) or stall (too much brake).
