Oil Temperature Gauge?
Old Jul 9, 2002 | 02:34 AM
uf300zx's Avatar
uf300zx
Default Oil Temperature Gauge?
Does anyone know where the Oil Temperature gauge is located in the car? I assume its built into the digital readout part of the 3 pod cluster. Is this true? I was happy to hear Nissan including this gauge in the car, as oil temp is critical to a engine as oil pressure.
Old Jul 9, 2002 | 03:38 AM
rai's Avatar
rai
I may be off on this, but isn't the radiator temperature a good indication of the oil temp? since the radiator is a cooling system the oil and coolant should be at or close to the same temp
Old Jul 9, 2002 | 03:58 AM
EnthuZ's Avatar
EnthuZ
Red face Oil is a three letter word
Do NOT Search for it
In the CD it was listed as an option on the #1 center dash pod/computer readout. But after reading all the tests so far, no one has mentioned it. If it is there, it would be dumb, as one could only choose between oil temp or the shift lights.
Oil temp is a much more important indication of the engines internal temp than water temp. I have both on my Jetta GLX, and the oil takes 2 or 3 miles longer to reach 200 degrees. I also had oil temp gauges on my race car and my Lotus, and the same held true. I don't want to beat an old horse or one doesn't do major physical work without warming up the muscles. Ditto a High Po motor.
Lots of reasons but I'm a crappy typist, so I'll end here.
Old Jul 9, 2002 | 04:39 AM
BILZ Z's Avatar
BILZ Z
Default Re: Oil Temperature Gauge?
Look at the Forbes article ZISME posted. There's a pic of 2 of the 3 instrument clusters. It appears that the oil temp is the center gauge.
Old Jul 9, 2002 | 05:08 AM
uf300zx's Avatar
uf300zx
The center gauge is oil pressure, not temp.
Old Jul 9, 2002 | 05:18 AM
EnthuZ's Avatar
EnthuZ
JDZ........
I don't understand your post. Oil pressure will/can be high even with a cold engine. Oil pressure has no(or little) bearing on the expansion rate of the rotating /or non moving pieces of the engine. I'll wait till all internal engine parts are "warm & comfortable" with each other before I ask it to perform.(I could interject a male/female thing, but I won't) The oil temp is the best way to monitor this.
A foreplay monitor
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
