About to install JWT Pop Charger...HELP
Old Jun 26, 2006 | 10:35 PM
VN_350z's Avatar
VN_350z
Default About to install JWT Pop Charger...HELP
After the nightmare I had to go through with HKS RS intake,
https://my350z.com/forum/intake-exhaust/192565-help-help-help-intake-problem.html
I wanna make sure I got it right this time.
I just bought a brand new JWT Pop Charger from Intense Motor Sport.
Any suggestion on installation? What should be the orientation of the MAF Housing? Should it be the same orientation as with stock intake or some people suggest to push it far right? I know MAF orentation decides wheather Z would be stalled(push it over 4k and put gear in neutral)
Any advice is greatly appreciated.
Old Jun 27, 2006 | 05:52 AM
THE TECH's Avatar
THE TECH
The popcharger comes with adequate instructions, you should have no probs.
Old Jun 27, 2006 | 06:52 AM
Blue_Z's Avatar
Blue_Z
make sure the arrows line up
Old Jun 27, 2006 | 07:20 AM
VN_350z's Avatar
VN_350z
What arrow lined up?
Old Jun 27, 2006 | 07:22 AM
NISMOdtc's Avatar
NISMOdtc
Old Jun 27, 2006 | 11:00 AM
THE TECH's Avatar
THE TECH
Just follow the instructions and there will be no probs.
Old Jun 27, 2006 | 11:18 AM
aren21's Avatar
aren21
Try unplugging the neg. terminal on the battery before you install it, it might save you from throwing codes, dont know if its true or not but I do it just to be safe. I guess leave the MAF orientation the same as stock, again I dont know if that matters or not.
Old Jun 27, 2006 | 12:36 PM
Fletch69z's Avatar
Fletch69z
It's really pretty easy and unless you replace your z tube you should have to change the orientation of the maf sensor.
Old Jun 27, 2006 | 12:38 PM
VN_350z's Avatar
VN_350z
What would be the correct orientation for MAF?
Old Jun 27, 2006 | 12:40 PM
Nexx's Avatar
Nexx
RTFM and you will have no problems.
Old Jun 27, 2006 | 12:46 PM
03zsmith25's Avatar
03zsmith25
does RTFM stand for what i think it does?
Old Jun 27, 2006 | 12:58 PM
VN_350z's Avatar
VN_350z
Sorry I am a newb. What RTFM stands for?
Old Jun 27, 2006 | 01:00 PM
BhashaZ's Avatar
BhashaZ
RTFM = Read the flipping manual.
EDIT: I didn't say that...I was just defining it.
Old Jun 27, 2006 | 01:28 PM
BhashaZ's Avatar
BhashaZ
Wow took me forever to search for these links, but here you go! This site has a videos of the installation:
http://350zroadsterclub.com/videosMenu.html
Also, you can look here for another "how-to":
http://www.speeddreams.net/350z/inta...t_install.html
Good luck!
Old Jun 27, 2006 | 01:30 PM
zdotcom's Avatar
zdotcom
Lightbulb
When you orient the MAF after attaching it to the Popcharger, you just need to make sure the plug for the MAF is still on top so you can plug it back in.
If all else fails, go to your trash can and dig past the pizza boxes and coffee grounds and find the manual you probably threw out when you got the popcharger in the mail! j/k
Old Jun 27, 2006 | 01:32 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Old Jun 27, 2006 | 01:33 PM
3hree5ive0ero
Retired Admin
Good luck!
You took all the fun out of letting him search for himself..
Old Jun 27, 2006 | 01:36 PM
VN_350z's Avatar
VN_350z
HTW am i supposed to see all these tutorials if I never saw them before?
Old Jun 27, 2006 | 01:42 PM
BhashaZ's Avatar
BhashaZ
Hahah...true, but sometimes those things are really hard to find! I couldn't even refind the original post that had those links. I found them in a 350Z Roadster thread because I knew the guy who posted them had a 350Z Roadster website!
I help because I understand it's hard to get find relevant info, especially when searching for "pop charger".
Old Jun 27, 2006 | 02:33 PM
3hree5ive0ero
Retired Admin
You're supposed to see those tutorials by searching.. That's why we have that function. Plus, if you have to ask how hard is installing a popcharger... Take it to a mechanic/dealership and save yourself the trouble.
