Base V Enthusiast
Old Jun 30, 2006 | 05:06 AM
Festus's Avatar
Festus
Default Base V Enthusiast
I am getting ready to purchase a Z. I am trying to decide between the Base and the enthusiast. I know there isnt much price difference but just wondered if it was worth it to spend the extra money. the only real benefit the enthusiast has that i want is limited slip. i was wondering from experience if it would make that much of a difference in hooking up. ive never had a rear wheel car before so just looking for some advice.
Old Jun 30, 2006 | 05:10 AM
nothix's Avatar
nothix
do all Z's come with TCS?
Old Jun 30, 2006 | 05:14 AM
Festus's Avatar
Festus
forgot about that. another advantage of the enthusiast
Old Jun 30, 2006 | 05:15 AM
jumpin800agl's Avatar
jumpin800agl
8 to 11
Default Enthusiast
I have an 04 Silver Enthusiast model. The limited slip does help some, the factory unit is a viscous limited slip. There are better aftermarket units available of course, one way to do it would be buy a base model and have one installed yourself. I like the xenon headlights that come with Enthusiast also.
Old Jun 30, 2006 | 05:17 AM
jumpin800agl
8 to 11
well once you get the car you will find yourself hitting that fun button alot to turn the TCS off.
Old Jun 30, 2006 | 05:24 AM
sq40's Avatar
sq40
HID is now standard on both base and enth.
Really the big differences are;
No LSD
No TCS or VDC
No Cruise Control
Base is a little Lighter.
Thats really about it.
I Guess the base is more of a "Driver's Car"
Old Jun 30, 2006 | 05:26 AM
theanswer0127's Avatar
theanswer0127
get the enthusiast.
other than lsd and tcs it's got cruise control, controls on the steering wheel, aluminum pedals, dash mounted storage, luggage box and a bunch of other lil stuff that might come in handy at times.
plus base trims r harder to find.
Old Jun 30, 2006 | 05:28 AM
theanswer0127
No LSD
No TCS or VDC
No Cruise Control
enthusiast doesnt have vdc
Old Jun 30, 2006 | 05:31 AM
sq40's Avatar
sq40
Right, It has TCS, But I also noted that VDC is not an option, as it is on other models too.
Old Jun 30, 2006 | 05:33 AM
pawnmarty's Avatar
pawnmarty
Default base vs enth.
get the performance edition it, has the most performance features without that f ing bose system (allways trouble)
Old Jun 30, 2006 | 05:36 AM
tlohman81's Avatar
tlohman81
I went with the enthusiast because I wanted the diff. I know you can put an aftermarket in but I would rather spend my money elsewhere right now. The TCS is nice to have to but like someone said earlier, you'll end up turning it off a lot. Nice to have though if you get stuck out in some bad weather though.
Old Jun 30, 2006 | 05:40 AM
The question may be decided for you: it will be very difficult to locate a 350Z Base. New or used.
Old Jun 30, 2006 | 05:43 AM
Festus's Avatar
Festus
saw 9 at dealership yesterday.
Old Jun 30, 2006 | 05:47 AM
zzzzzz ya's Avatar
zzzzzz ya
Enthusiast without a doubt.
Old Jun 30, 2006 | 06:11 AM
z350boy's Avatar
z350boy
I have an '05 enthusiast. I took this over the base for the reasons stated, that is the LSD & TCS systems. The base is a good alternative if you intend to upgrade the stock LSD and don't want/need the TCS.
Old Jun 30, 2006 | 06:24 AM
sq40's Avatar
sq40
Funny this thread came up, Me and a friend are going tonight to pick up his brand new redline base model from the dealership. he went over all of the options and features and decided the base was the best bang for the buck since there is so much aftermarket stuff out there.
Old Jun 30, 2006 | 06:30 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Keep in mind, so far as I have seen on this board and others Cruise Control is a factory only option, there are no kits to add it later.
Does the base come with the home link mirror these days?
Chris
Old Jun 30, 2006 | 07:08 AM
roast's Avatar
roast
Around here it's all about how much money you spend. The more you spend the more uber leet you will be regarded by the community. Buy the most expensive model and also give the dealer a healthy tip. Can't go wrong!
Sarcasm aside, to answer your question.... the open-end differential won't hurt your launches. You will generally only be able to notice it while accelerating hard and cornering hard at the same time. The viscous LSD also eats a little more horsepower than the open-end. The open-end would be a good differential to start with considering you've never driven a RWD car, then again the vlsd isn't much more aggressive so you probably won't have problems either way.
When all else fails test drive both and see what you think. You likely won't be able to push the car hard enough out of the box to even notice the difference.
Old Jun 30, 2006 | 07:38 AM
97supratt's Avatar
97supratt
Enthusiast for the kill.
